1970 454 - ground cable
Old Mar 19, 2009 | 02:51 PM
4howard's Avatar
4howard
Default 1970 454 - ground cable
We are reassembling a 1970 454 vert and have a 12" ground cable and cannot remember where it goes. A diagram would be helpful, but any suggestions would be appreciated.
thanks.
Old Mar 19, 2009 | 04:07 PM
Alan 71's Avatar
Alan 71
Hi 4H,
I believe it runs from the starter brace bolt on the side of the block to a bolt in the rear flange of the frame mount for the engine mount. Bolt and star washer at starter brace, and bolt, star washer and nut at the engine mount.
AIM UPC12 Sheet A11.
Regards,
Alan
Old Mar 20, 2009 | 07:01 AM
4howard's Avatar
4howard
Thanks for the quick response. We'll give it a look!
Old Mar 20, 2009 | 07:15 AM
4howard's Avatar
4howard
Hi Alan,
Can you tell me what and where to find the AIM UPC 12 Sheet A11? I am not familiar with what that is.
Thanks,
Howard
Old Mar 20, 2009 | 10:13 AM
noonie's Avatar
noonie
Old Mar 20, 2009 | 11:26 AM
superdad60's Avatar
superdad60
Would my 68 vert have the same places for that ground cable?
Old Mar 20, 2009 | 11:58 AM
SIXFOOTER's Avatar
SIXFOOTER
Probably. Exact location is not very important. The object is to get a good hugh current ground from the engine block to the frame. Just keep it as far away from the headers as possible and don't interfere with anything else.
Old Mar 20, 2009 | 04:04 PM
Alan 71's Avatar
Alan 71
Hi Howard,
The AIM is the ASSEMBLY INSTRUCTION MANUAL, it's engineering drawings that show how the car was assembled in St Louis. It's 417 pages for 71. There is one for each year.
It and the GM CHASSIS SERVICE MANUAL for each year are priceless to anyone working on a 30+ year old car. Most vendors sell them as does the NCRS Store.
I used the AIM so much during my restoration that I'm on my third copy.
Regards,
Alan
Old Mar 20, 2009 | 04:05 PM
Alan 71's Avatar
Alan 71
Hi SD60,
Yes, your 68 has a similar ground cable and connections.
Regards,
Alan
Old Mar 22, 2009 | 12:51 PM
4howard's Avatar
4howard
Thanks!! A picture's worth a thousand words!
Old Mar 22, 2009 | 12:52 PM
4howard's Avatar
4howard
4howard's Avatar
4howard
not sure.
4howard's Avatar
4howard
not sure.
Old Mar 22, 2009 | 12:53 PM
4howard's Avatar
4howard
Originally Posted by Alan 71
Hi Howard,
Regards,
Alan
Thanks for the info.
To 1970 454 - ground cable
