high acelaration miss problem, Need Help!!!
Old Mar 20, 2009 | 12:44 AM
74convertible's Avatar
74convertible
4th Gear
Default high acelaration miss problem, Need Help!!!
I just installed an HEI distributor frm midamerica motorworks in my 74 vette, it is a 350 4spd, I had a slight cutout before i installed, however now it is much worse with new distributor, At around 3750 rpm's it starts to cut out really bad, I installed as told with timing set without vacuum at 6 deg. when you hook up vacuum it goes of the chart at idle?
There were also 2 wires hot from ignition I hooked to battery side of distributor, same wires from pos. side of old coil. I'm really out there guy's. Can anyone shed light on my problem?
Old Mar 20, 2009 | 04:16 AM
c31980's Avatar
c31980
what else did u change ?? check your carb for vac leak ,spark plugs wires ,fuel pump & fuel lines
i think you have a timing issue
Old Mar 20, 2009 | 07:13 AM
midyearvette's Avatar
midyearvette
your timing at 8 and way up after you hook up the vac. is fine...sounds like a chafed or bad plug wire or possibly a bad capacitor if you have one hooked up on the pos. side of the coil for starters.....
Old Mar 20, 2009 | 09:39 AM
74convertible
4th Gear
I have changed plugs right before changing distributor, also installed new aacel 9000 hei wires, one thing puzzled me installing new dist. was 1 wire hookup, there were 2 small wires together going to the old coil system on pos. side, so we checked, both were hot on ignition, and we just plugged them back together to batt. or ign. side to new hei distributor. plugged vac. line that was from old hookup on new distributor, I just was figuring it had to be the timedport vac. since it was same hose.
Old Mar 20, 2009 | 11:24 PM
74convertible
4th Gear
Hey Guy's, Found my problem if this ever happens to anyone else, on the older points type distributors the wire used for the coil is 12 volts, however it is a resistor type wire..... looses voltage under heavy load.
Thank God this was not as bad as I thought. Now I just have to figure out how to get to it for replacing. I hooked a jumper to distributor on a constant hot 12 volts and she ran like a dream. Any suggestions on how to trace the resistor wire to where it stops to replace? or maybe another good fire source hot on ignition under the hood? Thanks
Old Mar 21, 2009 | 12:40 AM
SIXFOOTER's Avatar
SIXFOOTER
There should have been 2 wires on th + side of the coil before. 1 yellow to the starter is the bypass wire for starting, you can eliminate that one all together. The other wire goes to the firewall connector and that one is the resistance wire. You can clip and splice in a new wire at the firewall connector and you should be good to go. I have 2 drawings, 1 shows it as a White wire with red/black tracer 20#, the other shows it as Black and pink.
Old Mar 23, 2009 | 11:03 PM
74convertible
4th Gear
Thanks for advise, I will try to get on rack to trace it, it is blk w/pink wire, do i need to take out of block or just splice it? Jim
Old Mar 24, 2009 | 10:24 PM
DC3's Avatar
DC3
Just run a new wire. I had a similar problem with my '73 which had been converted to HEI. Previous owner knew to get 12 volts to the HEI but didn't do something right and wasn't getting full voltage. The guy I had dyno tuning my engine bypassed the resistor wire and ran a new pink wire from an ignition source under the dash back to the distributor. He said pink was the correct color for an HEI wire and would make it easier in the future for others to diagnose.
DC
To high acelaration miss problem, Need Help!!!
