Speedo back powered Vacuum connection
Old Mar 20, 2009 | 11:30 AM
superdad60's Avatar
superdad60
Default Speedo back powered Vacuum connection
Had the dash apart and on the back of the speedometer is a two in and one out vaccum connection
There is a two pring power connection on it too...
Wnayone know what this is?
Does it deal with the wiper cowl? as mine was replaced and no longer goes up and down but these parts are still behind the dash
thanks
Old Mar 20, 2009 | 01:25 PM
DZRick's Avatar
DZRick
Sounds like your talking about the wiper motor solenoid, it actually has 2 vacuum lines. That 3rd port at the bottom is a filter.
This little thing, right?
http://www.ecklers.com/product.asp?p...3&dept_id=1326
Old Mar 20, 2009 | 01:26 PM
griffths's Avatar
griffths
superdad,
It sounds like the wiper door relay but normally it is mounted to the back of the tach. If you don't have the wiper door anymore you can safely remove it. I would suggest that you keep all of the parts you are removing since original parts have value to those who are restoring their cars.
Regards,
Jay
Old Mar 20, 2009 | 01:46 PM
superdad60's Avatar
superdad60
That is the item and thanks
Do you happen to know the colored wires that attach to this baby?
Old Mar 20, 2009 | 03:43 PM
Alan 71's Avatar
Alan 71
I believe # 18 light blue and 2 #18 yellow with 1 connector. (1971)
Regards,
Alan
To Speedo back powered Vacuum connection
