Differential Identification?
Old Mar 22, 2009 | 03:05 PM
AvRog's Avatar
AvRog
Default Differential Identification?
Hi All, Just removed the rear spring on my 69 to inspect a bad leak I thought was the Diff plate seal. Now i think its coming from the diff case where the spring mount bolts go into the case. Are these bolts supposed to penetrate the diff case? If so how is this sealed?
The options on the car show GS2 and G81, 3.08 gear and a positraction differential carrier. The red tag says use limited slip oil, is this correct or have I been Bubba'ed.
Old Mar 22, 2009 | 03:23 PM
Gordonm's Avatar
Gordonm
Someone used bolts that are to long and they go into the case and break through to the oil. This is common among Bubba. You will probably need a new cover and use the correct bolts. Some have sealed this off but the correct fix is to replace the cover with a HD cover and use the right bolts.
Old Mar 22, 2009 | 03:32 PM
Alan 71's Avatar
Alan 71
Hi AR,
Those 4 bolts should be 9/16"-12 x 3 1/8". The rear 2 can be a little long, the front 2 can't be.
Regards,
Alan
Hi G, you beat me while I was looking for the length!
Old Mar 22, 2009 | 03:48 PM
AvRog's Avatar
AvRog
Ok guys, thanks. What about the oil, should it be limited slip or positraction oil?
Old Mar 22, 2009 | 04:27 PM
Gordonm's Avatar
Gordonm
These are the same thing. Limited slip and positraction mean the same thing so yes it should be that. Also get the GM posi additive.
Old Mar 22, 2009 | 04:36 PM
AvRog's Avatar
AvRog
Thanks, I hadn't noticed before as I am a sloppy worker and left the bolts lay where they fell, one of the 4 is 4 inches long, theres my leak. Thanks again.
Roger.
To Differential Identification?
