Dash pad removal help
Old Mar 23, 2009 | 11:18 AM
71coupe454's Avatar
71coupe454
Default Dash pad removal help
Everything is out of my dash except the dash pad. how the heck does it come out? I have the side pillar trim off also. I cant see how to get the corners past the window frame. I tried sliding one end up but it wedges in the frame. Anybody know the trick?
Old Mar 23, 2009 | 11:19 AM
QuicheLorraine's Avatar
QuicheLorraine
Roll the car out into the sun and let it sit for an hour. Flex the dash pad in the middle, a few inches and then tilt it out. It's a PITA for sure but it will come out.
Old Mar 23, 2009 | 11:25 AM
71coupe454's Avatar
71coupe454
Dang, its old and I was hoping to get it out to dye it and back in with out cracking it. Guess I'll have to wait for a hot day.. Thanks
Old Mar 23, 2009 | 12:11 PM
Peterbuilt's Avatar
Peterbuilt
Seems like the old dash pads can crack with just a little bending, broke mine while trying to replace the speakers, now I have new speakers and a new dash, PG
Old Mar 23, 2009 | 12:30 PM
71coupe454's Avatar
71coupe454
And they aint cheap either.. I checked mine out again, hard as a rock! Wonder if I can manage to dye the pad with it still in?
Old Mar 23, 2009 | 04:58 PM
Alan 71's Avatar
Alan 71
Hi 71,
Since the 'blacked-out' area of the windshield hides the front edge of the dash pad you might just get away with dyeing it in place.
Good Luck!!!!
Regards,
Alan
Old Mar 23, 2009 | 08:57 PM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
I had a similar problem and I got help from the Willcox site. They have documentation on all sorts of stuff including the dash pads. There is a sequence to follow, and when I followed it I got it right out without cracking it.
You might want to check it out, couldn't hurt.
Best regards,
David
77Sleeper
Old Mar 23, 2009 | 09:00 PM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
Found it. dash_pad_removal_instructions_new_with_pics_2.pdf
I hope you find it helpful.
David
77Sleeper
Old Mar 23, 2009 | 10:35 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Pat,
Give me a call tomorrow if you don't figure this out. Maybe I can run and help you with this.
My directions should tell you how http://willcoxcorvette.com/repairand...lp.php?hID=105
Just in case. . . If you push the pad to the driver side of the car as far as possible, then push upward in the center of the pad while pulling downward on the passenger side you'll get it out. Don't crack it. . . If you don't get it out, I can run by and take a look at it and guide you! I can't do it, but I sure as H377 can show you!
David,
I didn’t know this was my link you posted. In picture G it shows you where to push. Pat is only in the next town over so if he is stuck, I’ll free up some time and show him.
Willcox!
Old Mar 24, 2009 | 10:21 AM
71coupe454's Avatar
71coupe454
Hey thanks guys, I'll give it a try after i take out the defrost vent so it dont break in half with the dash when it goes..lol theres no hot sun today, would a heat gun to the middle part help my chances any? and Ernie I could use some advice on a few things on this car so any time you get a chance let me know. 2706 hollywood blvd!
Old Mar 24, 2009 | 11:21 AM
7T1vette's Avatar
7T1vette
A heat gun...used improperly...will damage, warp, or melt the vinyl surface. Unless you know what you're doing, don't use the gun. If you can't get the car into the sun (or don't have an electric blanket to put over the dash for a few hours), just be careful and don't use excessive force to 'wrestle' it out. Take the help offered, if you need.
Old Mar 24, 2009 | 01:22 PM
71coupe454's Avatar
71coupe454
The heat gun came in a big azz tool box full of stuff I bought., never used it before, so i left it in the tool box.. lol I sat one of those yellow square shop lights in on the trans hump aimed up at the dash pad. Sanded on my firewall for a while and just now got in and pushed and pulled like in Willcox info and it came right out with no cracks.. Now I got one hell of a mess!
Old Mar 24, 2009 | 03:37 PM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
Congratulations...does yours look more like this now?
Name:  Upper Dash Pad Removed.JPG
When I was at this point I thought there would be no way I would ever get it back together.
Looks much better now. Now for that weather stripping...
Name:  Interior Completed 2.JPG
Name:  Interior Completed 3.JPG
Keep the faith brother, your efforts will be rewarded...
Best regards,
David
Old Mar 24, 2009 | 04:13 PM
Paul L's Avatar
Paul L
Attachment 47636190
Attachment 47636192
Attachment 47636191
Best regards,
David
How did you get that weatherstripping off?
Old Mar 24, 2009 | 07:00 PM
7T1vette's Avatar
7T1vette
Word to the wise.... Do not get in a hurry--or you will regret it. Double-check everything with the A.I.M. when you go back together.
Old Mar 24, 2009 | 07:22 PM
71coupe454's Avatar
71coupe454
Hey that looks pretty good, I'll keep it in mind and try not to loose hope! lol Mine looks pretty bad now, the dash pad was the last thing left. I was just going to put my 4-speed pedals in when I started but one thing lead to another..
Old Mar 24, 2009 | 07:41 PM
Dream Ride's Avatar
Dream Ride
St. Jude Donor '09
Great Thread.
To Dash pad removal help
