1969 electrical failure
Old Mar 24, 2009 | 01:00 AM
Pheckmann's Avatar
Pheckmann
4th Gear
Default 1969 electrical failure
What would cause a complete electrical failure on my 69 vette. the battery is fully charged?
Old Mar 24, 2009 | 01:32 AM
Peterbuilt's Avatar
Peterbuilt
You could have blown a "Fuseable" link. There is one at the starter, two at the horn relay and one for the ammeter. They burn and open inside the insulation so you have to pull them from each end to see if they a good or not, or use a meter and check for continuity at each end. PG.
Old Mar 24, 2009 | 03:05 AM
GunPowder's Avatar
GunPowder
Do you mean no power at all?
Loose battery main wires (ground cable to frame below battery, positive cable to starter).
Old Mar 24, 2009 | 11:35 AM
7T1vette's Avatar
7T1vette
I believe that a bad battery feed or ground wire/connections are the only possible causes for everything going out.
Old Mar 24, 2009 | 03:20 PM
Solid LT1's Avatar
Solid LT1
Second vote for fuseable link by the starter motor. Check voltage from horn relay terminal to engine block if there isn't any there you have a fuse link problem down by the starter motor (one of the horn relay terminals is powered up all the time, easy to check.)
Old Mar 24, 2009 | 04:24 PM
Roughrider's Avatar
Roughrider
The fusible link as already mentioned is a prime cause for the problem...also bad battery connections or ground.
One less common problem could be the ammeter. Everything or nearly everything goes through that. If the gauge is bad it could cause the problem. Not a likely cause, but still a potential cause.
Old Mar 24, 2009 | 06:57 PM
7T1vette's Avatar
7T1vette
Correction... Very little current flows through the ammeter. Sorry to differ. That device is really a millivolt meter which 'measures' current flow through one of the major 12 volt supply wires. The "ammeter" really measures the voltage drop across a specific length of that supply wire, but the dial face is scaled in to read in "amps". [it's probably the most misunderstood component in the C3 Corvette...]
Old Mar 24, 2009 | 08:20 PM
SIXFOOTER's Avatar
SIXFOOTER
yep
To 1969 electrical failure
