L-46
Old Mar 24, 2009 | 05:04 PM
wcdknows's Avatar
wcdknows
Default L-46
How much rwhp did that engine make?
Old Mar 24, 2009 | 05:10 PM
PuddleJumper's Avatar
PuddleJumper
i will have a look for you ok
Old Mar 24, 2009 | 05:11 PM
wcdknows's Avatar
wcdknows
Old Mar 24, 2009 | 05:34 PM
PuddleJumper
what year is it??
Old Mar 24, 2009 | 05:48 PM
Mike Ward's Avatar
Mike Ward
GM did not release rwhp numbers, only gross HP. My guess is in the low 200's.
Old Mar 24, 2009 | 05:50 PM
PuddleJumper
i think he means the L48 witch was 180-195 BHP
Old Mar 24, 2009 | 05:55 PM
wfo76's Avatar
wfo76
L46 produced 69 and 70 only and both rated at 350 gross flywheel hp.
L46 is basically an 11 to 1 version of the L82 as it uses the same cam.
Rear wheel hp? I would guess 250 to 260 rwhp.
Old Mar 24, 2009 | 06:30 PM
dennis's Avatar
dennis
I did my 70(370 gears) a few years back with a G-tech. 3-4 runs averaged mid 250's rwhp. 0-60 was a dog in the mid 6's. Forget the 1/4 time but I believe the speed was in the 103-105 range. Great top end ,dog out of the box
Might not be exact, but it sure was fun
Old Mar 24, 2009 | 06:47 PM
pws69's Avatar
pws69
That's interesting! Are you sure they are 370's? I have 370's in my 69 L-46 and it's insane at the low end! Been enough over a buck to be satisfied so it doesn't suffer at the top end either.
Old Mar 24, 2009 | 08:25 PM
wcdknows's Avatar
wcdknows
It's a 70
Old Mar 24, 2009 | 08:45 PM
dennis's Avatar
dennis
Insane compared to what?
The cam in the L-46 is not agressive in the low RPM range. Real screamer up top though.
Old Mar 24, 2009 | 09:42 PM
69 Convertible's Avatar
69 Convertible
I had rebuilt my 69 L46 last year. Dropped the compression down to 10.50,
Edelbrock Performer intake, stock 2.02 heads, stock Qjet, Hedman header, roller tip rockers, roller cam and lifters, crane cam. Had it dynoed and got like 320 HP, and 278 RWHP not the numbers I expecting after the rebuild. If I Put an Edelbrock head, it would give me another 30-40 HP. But that's going to be a long time from now. Just glad that it's running and on the road.
Old Mar 25, 2009 | 12:22 PM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
One reason why the L46 cam at low rpm is not as highly thought of as the 327/350 HP cam, in spite of the fact that the durations are nearly identical, is that the 327/350 (L79) cam is 4 degrees advanced versus the L46. Just advance the L46 by 4 or 6 degrees and smile!
Better yet, tighten the lobe separation angles with an aftermarket cam to 110 or 108 degrees.
To L-46
