1978 L-48 engine upgrades
Old Mar 25, 2009 | 06:51 PM
MNTWINS33's Avatar
MNTWINS33
Default 1978 L-48 engine upgrades
After replacing my manifolds with headers, what other upgrades can i add to gain horse power? and at what point will i have reached the power of a L-82?
Old Mar 25, 2009 | 07:12 PM
jbowles49's Avatar
jbowles49
If I wanted to wake up that motor I would look at a top end swap. Vortech heads with manifold appear to be a viable swap for not a ton of money. Many GMPP outlets have packages available. Of course the cam etc. will need to be changed to take advantage of the new heads and proper recurve of dist. If you do something like this consider getting the heads already cut for additional lift as limit on vortechs was about.480 as I recall. Should be way stronger than an l82. Good luck
Old Mar 25, 2009 | 07:24 PM
Duke94's Avatar
Duke94
Old Mar 25, 2009 | 09:16 PM
PuddleJumper's Avatar
PuddleJumper
Default question
where might one find the specs such as flow rates at veryus valve lifts for the Vortec Heads??
asking for me and MNTWINS33
oh it might be an half good idea to get an Verteral Dyno to test various combos i have DynoSim2003
Ryan
Old Mar 26, 2009 | 02:46 PM
Reggie Dunlop's Avatar
Reggie Dunlop
with the headers, true duals, and no cats, you have exceeded the stock L82 in horsepower and torque. If your carb and ignition are optimized you've passed it by a good margin. The next logical step would be a cam in the 204/214 420/440 112 range. Still not too much for the putrid L48 comp ratio, but just enough cam to enhance the lower RPM and pull hard in the mid range up to 5,000 RPM. With gears in the 3.08 to 3.23 range your car will run in the high 14s.
To 1978 L-48 engine upgrades
