fluid won't flow
Old Mar 26, 2009 | 09:46 PM
dburgjohn's Avatar
dburgjohn
Default fluid won't flow
new brake system booster, MC all lines flex and metal. Could not bleed. I have motive pressure bleeder and vacuum bleeder, even both at same time moved no fluid.
I removed Porportioning Valve and blew air in from all four wheels (thru bleeder screw) and heard the air come out other end of lines. blew air thru porportioning valve and it went through. Tried bench bleeding MC again and held lines out of fluid on push so I could see it flow.
what is going on?
Old Mar 26, 2009 | 11:21 PM
mds3013's Avatar
mds3013
Did mc bench bleed normally? If it seems ok, does booster rod push on mc when you bolt it on causing valve to cover refill holes in mc?
Old Mar 27, 2009 | 02:34 PM
dburgjohn's Avatar
dburgjohn
bench bleed twice. correct short rod in booster, makes contact but does not 'push' during install
Old Apr 1, 2009 | 12:12 AM
dburgjohn's Avatar
dburgjohn
new Porportioning Valve, flows now
Old Apr 1, 2009 | 12:26 AM
Peterbuilt's Avatar
Peterbuilt
Did you take the old valve apart to see why that happened? I though they would at least flow fluid to one side. PG.
Old Apr 1, 2009 | 09:35 AM
dburgjohn's Avatar
dburgjohn
if by 'take apart' you mean turn a hand held grinder on the part that caused me such pain then yes. As for what was wrong, kind of hard to tell now
To fluid won't flow
