need side marker template
Old Mar 27, 2009 | 10:44 PM
TOM B1's Avatar
TOM B1
Default need side marker template
I need a template to cut in side marker holes, front & rear, or a wrecked piece of your old fiberglass with the light hole still intact.
On my 69 vette, they where glassed over and I think I need them for state inspection. but I forget what the hole looks like and where to cut it.
thanks.
Old Mar 28, 2009 | 11:57 AM
Alan 71's Avatar
Alan 71
Hi Tom,
I'd drill a hole from the inside of the fender through the hole for the bulb connection. This will give you a center to start cutting from until you get to the remains of the original recess for the receptacle and lens. Having a side marker on hand will help you know where to cut and how much.
Can you tell if this car was hit in the front and that's the reason for the 'custom' front-end work?
Regards,
Alan
Old Mar 28, 2009 | 09:29 PM
TOM B1's Avatar
TOM B1
The car was custom from way back when my brother bought it in the mid 70's. the front and the rear is custom with very wide flares, looks like a road racer car. The rear side light holes are missing also, so I guess if the whole car is custom, a little off with my holes wont matter.
I need a close up pic of the marker hole inside and outside so I can cut it out right or a smashed piece with the marker hole intact would be great.
Old Mar 28, 2009 | 10:48 PM
DZRick's Avatar
DZRick
Tom,
I can get pictures of the fronts for you tomorrow, I already gave the one rear bezel I had away.
This is from a 68 which is the same as the 69.
Old Mar 29, 2009 | 12:41 PM
TOM B1's Avatar
TOM B1
Thanks DZ
Old Mar 29, 2009 | 01:56 PM
DZRick's Avatar
DZRick
Here you go Tom.
Right side is facing front bumper
Left is facing FB
Old Mar 29, 2009 | 04:23 PM
Alan 71's Avatar
Alan 71
Hi Rick,
Nice pictures!
I thought I'd see some way for the side-marker to be fastened into the fiberglass. How are they held in in 68-69?
Thanks!
Regards,
Alan
Old Mar 29, 2009 | 07:28 PM
TOM B1's Avatar
TOM B1
Thanks for the pics DZ.
PM sent.
Old Mar 29, 2009 | 07:53 PM
DZRick's Avatar
DZRick
Originally Posted by Alan 71
Hi Rick,
Nice pictures!
Thanks!
Regards,
Alan
This metal cup sort of pinches the fiberglass between it and the lens.
Old Mar 30, 2009 | 02:14 PM
Alan 71's Avatar
Alan 71
Hi DZ,
Again... nice pictures!
Thanks,
Regards,
Alan
Old Mar 30, 2009 | 02:36 PM
DZRick's Avatar
DZRick
Hi DZ,
Thanks,
Regards,
Alan
Alan,
I just need some models to liven up my photos.
To need side marker template
