74 Security System
Old Mar 28, 2009 | 09:53 PM
jordan89's Avatar
jordan89
Default 74 Security System
Hi I'm new here and need help with my 74 Stingray. Can anybody tell me a little about how the security system on my 74 Stingray works? This is my first Corvette and I've always wanted one. I bought the car running and when I started moving some ***** and things that where under the steering column the car didn't even start any more, the engine doesn't even turn or anything, the lights and things come on but the car won't start and I need to know if this is part of the security system. Please help. Thank you
Old Mar 28, 2009 | 11:49 PM
Peterbuilt's Avatar
Peterbuilt
Default Won't start!
Hi jordan89 and welcome to the forum. The security system will not stop you from starting your Vette unless there is a short that is draining you battery. First thing to do is bring the battery to the auto parts store and make sure it is good and fully charged, take a look at the negative cable and make sure the end is on tight tight where it connects to the battery then check the other end where it hooks to the frame, remove the cable from the frame clean the connection with a wire brush and secure the cable back to the frame. Then check the positive cable where it connects to the battery, then go to the starter ( on the lower right side of the motor ) and make sure that connection is tight.
On an automatic there is a neutral safety switch that prevents the car from starting in other than P or N, on a stick you must hold the clutch pedal to the floor.
Hpoe that helps. PG.
Old Mar 29, 2009 | 02:00 AM
jordan89's Avatar
jordan89
I am going to check if the neutral safety switch is plugged up and check some more of the wiring. It is a 4 speed manual. I don't know what happen, it was starting right up. Thanks for the help, I'll try those things tomorrow.
Old Mar 29, 2009 | 02:04 AM
jordan89's Avatar
jordan89
Oh. Also, to activate the alarm I just turn the key and pull the key, and to deactivate it I just turn the key back up right?
Old Mar 29, 2009 | 09:58 AM
Paul L's Avatar
Paul L
The alarm system is a just a horn activated by switches on the door jambs and the hood. It has nothing to do with ignition. You probably have run into the infamous 1974 seat belt interlock system whereby the car will not start unless the seatbelt is connected. That would be plural if you have a passenger. Most of these nuisances have been disabled but perhaps yours has not. Try (1) connecting the seat belt. If that does not work (2) push in the system re-set button on the firewall, passenger side.
Quote from history:
Also new for 1974 was a federally-mandated interlock system that required the driver and front-seat passenger to fasten their seat belts in order to start the car. This regulation, which was very unpopular with the buying public, was offered only this one year and on some early 1975 models. It was rescinded by Congressional action due to the public uproar.
Old Mar 29, 2009 | 10:59 AM
Peterbuilt's Avatar
Peterbuilt
Paul74 good call on the security interlock, I forgot all about that since I went under the seats and unpluged that connection. PG.
Old Mar 29, 2009 | 01:57 PM
jordan89's Avatar
jordan89
That would probably explain why the connection under the seat was disconnected. That pic was very helpful, thanks. I'm going to try those things.
Old Mar 29, 2009 | 02:02 PM
Mike Ward's Avatar
Mike Ward
Your car does not have a neutral safety switch, it has a clutch interlock.
It won't crank if the the clutch pedal is not firmly against the floor.
Old Mar 29, 2009 | 02:11 PM
jordan89's Avatar
jordan89
That's very helpful information and history that I did not know.
Old Mar 29, 2009 | 07:29 PM
Paul L's Avatar
Paul L
Let us now if you sorted this out. Info/solutions are valuable to other 1974 owners for this unique and one-year bizarre federal legislation on 1974 vehicles. You sit on a seat and the car won't start??
Old Mar 29, 2009 | 08:08 PM
jordan89's Avatar
jordan89
GOT IT. It was the belts that were causing the problem. All I did was disconnect the plug at the bottom of the driver seat, for the belts, and it started right up, well not really because the battery was low, but the engine turned over. I did try to turn the car on when I buckled both the belts but it didn't turn on, I don't know why, so I just unplugged that belt sensor and it turned on.
Old Apr 8, 2009 | 08:19 PM
21boy's Avatar
21boy
I don't know if they where meant to do this or if my seat belt sensors are getting smarter over the years but if you just keep the belt buckled and try to turn the car over it knows it was buckled from the last time and denies you.. It's a real pain..
Old Apr 8, 2009 | 10:36 PM
goinbroke's Avatar
goinbroke
Here's a link having to do with the interlock system that might be helpful to 74 owners.
http://home.comcast.net/~vettfixr/page16.htm
To 74 Security System
