Replace Dot5 with Dot3
Old Mar 29, 2009 | 02:57 PM
VictoriaVette's Avatar
VictoriaVette
Default Replace Dot5 with Dot3
I know you are not suppose to mix dot5 with any other brake fluid but can the system be flushed to replace it with dot3? Anyone ever do this?
Old Mar 29, 2009 | 04:47 PM
Roughrider's Avatar
Roughrider
There's no reason why not but you have to make sure you completely flush the old fluid out and make it's it's dry before adding new fluid. The procedure should be the same as replacing Dot 3 with Dot 5 as the reverse.
You just want to make sure all vestiges of the old fluid are purged completely. Rebuilding the calipers with new seals would be a good thing as well.
Old Mar 29, 2009 | 05:12 PM
Bond007's Avatar
Bond007
VictoriaVette,
Why on earth would you want to go back after going through
the process of replacing 3 with 5????
Old Mar 29, 2009 | 06:15 PM
Bee Jay's Avatar
Bee Jay
I had this done about 20 years ago. I think they flushed the system with alchohol to get rid of the DOT 5, before refilling with DOT 4. That DOT5 was bad news, mostly for concourse weenies, not for any high performance driving. I run synthetic DOT4 now.
Bee Jay
Old Mar 29, 2009 | 08:17 PM
VictoriaVette
It sound like it will be more costly than to just keep my Dot5. I owner of my 77 put new calipers and master cylinder on it and started using Dot5. I need to bleed the brakes and Dot5 is very costly in it self but I guess I'll keep it. Thanks for the replies.
Old Mar 29, 2009 | 08:35 PM
Bee Jay's Avatar
Bee Jay
Your sig has dual exhaust, rpm manifold, aluminum heads, and a cam. I bet you drive your car hard and fast occasionally. I like to drive mountain and canyon roads. Every once in a while you have to haul it down from superlegal speeds to 15mph for a hairpin or three. The silicone would get spongier on me as the day wore on. Other than that, Dot 5 was great, and back in the day, we all put in Dot 5 to save our precious factory brakes from corosion. When you upgrade to Wilwoods or stainless sleeves, that would be a good time to get rid of the sillycon. Your results may vary.
Bee Jay
Old Mar 30, 2009 | 10:08 AM
Crash80's Avatar
Crash80
So....what would happen if DOT 5 and DOT 3 were mixed? Just curious....
Old Mar 30, 2009 | 10:18 AM
Roughrider's Avatar
Roughrider
The two types are not compatible. You'll end up with a cloudy mess in the brake lines and lots of air bubbles that won't bleed out. The car will end up with very mushy brakes that defy correction until completely flushed.
Old Mar 30, 2009 | 11:18 AM
FB007's Avatar
FB007
Pretty much the same as water in your oil.
Old Mar 30, 2009 | 02:22 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Originally Posted by Bee Jay
...That DOT5 was bad news, mostly for concourse weenies, not for any high performance driving. I run synthetic DOT4 now.
Bee Jay
I've never put it quite like that, but my sentiments exactly. Curious as to which fluid you're using now; Valvoline or other?
TSW
To Replace Dot5 with Dot3
