Battery Cables
Old Mar 29, 2009 | 10:51 PM
hdpete98's Avatar
hdpete98
Default Battery Cables
How do you get the rubber grommets in the holes in the body? I just can't get them to pop in.
Old Mar 29, 2009 | 11:15 PM
chvet73's Avatar
chvet73
I'm not sure which grommet you mean but the ones on the firewall go in real easy with a little WD40.
Old Mar 30, 2009 | 09:25 AM
mayberg's Avatar
mayberg
I did it with a long metal rod and a BFH.
I agree - not easy, but that fiberglass seems to be pretty stout.
Old Mar 31, 2009 | 06:05 PM
doctorgene's Avatar
doctorgene
Hey guys, just heat a pan of boiling water and dip the plugs in an presto they go right in an swell right back out when they cool off. I used this trick building my 57 chevy the first time and it works without making a mess on the paint, I did use gloves and a taco thongs. Doctorgene
Old Mar 31, 2009 | 06:26 PM
Duke94's Avatar
Duke94
I assume you mean the grommets that are molded onto the battery cables where they go through the floor pan. Heat the rubber grommet with a hair dryer to soften it. Then use a little dish soap mixed with water and coat the grommet and hole. Work quickly here so the grommet doesn't get cooled off. It "should" snap into the hole.
Gary
Old Apr 2, 2009 | 03:51 AM
hdpete98's Avatar
hdpete98
thanks Gary, that sounds like it should work. but how do you explain a hair dryer in the tool box? LOL
Old Apr 2, 2009 | 09:30 AM
Duke94's Avatar
Duke94
Don't tell the wife, but I use her hair dryer for car projects once and a while. Works good installing new carpet also.
Gary
Old Apr 2, 2009 | 12:39 PM
my 76 ray's Avatar
my 76 ray
Call it a heat gun.
To Battery Cables
