differential fluid
Old Apr 2, 2009 | 06:56 PM
mrmarchuk's Avatar
mrmarchuk
Default differential fluid
would this work as differential fluid? the local autozone guy said it should do the trick... im just wondering what trick ya know? i dont wanna unwillingly "Bubba" my car
sorry for the quality... low but w/e. used my phone.
edit: my car is a '79
Old Apr 2, 2009 | 07:03 PM
Gordonm's Avatar
Gordonm
In a pinch it would work but I would not run it in the rear of a posi unit. Get the correct posi fluid and additive from GM.
Old Apr 2, 2009 | 07:06 PM
rajsid's Avatar
rajsid
I believe that 80W-90 is what the owners manual recommends.
It should work. The brand does not matter besides Valvoline is good.
If it is a posi traction diff, you may also want to add one of these.
These are available at the local GM dealer.
Old Apr 2, 2009 | 08:51 PM
mrmarchuk's Avatar
mrmarchuk
sweet. thanks for the tips ill probably stop by and pick up some additive tomorrow
Old Apr 5, 2009 | 02:00 PM
hdpete98's Avatar
hdpete98
Make sure you add the GM additive. Without it or with another brand, you will have trouble.
Old Apr 6, 2009 | 09:38 AM
mrmarchuk's Avatar
mrmarchuk
yup. i did. i put in 1 1/2 tubes of the w90 oil and one tube of the additive, thats all that could fit without overspilling
Old Apr 6, 2009 | 10:23 AM
73, Dark Blue 454's Avatar
73, Dark Blue 454
That's what I use in six cars all with posi,..Valvoline 80-90 with the GM additive.
To differential fluid
