Astro Ventalation
Old Apr 3, 2009 | 04:45 PM
nutovette's Avatar
nutovette
Cruising
Default Astro Ventalation
Can anyone tell me how the rear vent works on a '69 roadster you know the one across the rear deck?? It looks like it is vacuum operated but I am not sure what switch controls it or what it is connected to. Right now it is open, I've tried all the magic words I know to close but no luck. Any info. would be appreciated.
Roger
Old Apr 3, 2009 | 06:00 PM
Duke94's Avatar
Duke94
One of the thumb wheels on the heater controls opens and closes it. On my 71', the steel tube that goes from the center console back to the vacuum actuator rusted through so it was not getting vacuum to close it.
Gary
Old Apr 3, 2009 | 10:07 PM
tfi racing's Avatar
tfi racing
It doesn't.Just free it up enough so that it wil close and forget it.Another GM marketing gimmick that really never did anything but give a bunch of bored engineers something to do.
Old Apr 3, 2009 | 10:14 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
The Astro Vent allowed fresh air to flow through the car as long as the temperature control is set to minimum. Move the dial away from minimum toward warm and vent should close keeping the warm air in the car.
Old Apr 3, 2009 | 10:23 PM
joewill's Avatar
joewill
Old Apr 4, 2009 | 10:19 AM
78whtshark's Avatar
78whtshark
does this also apply to a roadster with A/C? Someone told me they should not operate on an A/C car?
Old Apr 4, 2009 | 11:02 AM
70Yellowbird's Avatar
70Yellowbird
I don't have A/C in my '70, but others have said in other threads that the rear vents stay closed in an A/C car. I'm not sure of the exact configuration, but the car w/ A/C should not need an air actuator.
Old Apr 4, 2009 | 12:15 PM
Alan 71's Avatar
Alan 71
It's true that cars with A/C have block-off plates on the Astro plenums in place of the 'flapper' doors.
Regards,
Alan
Old Apr 4, 2009 | 01:19 PM
Duke94's Avatar
Duke94
According to the AIM for my 71', cars with A/C had a block off plate screwed to the opening instead of the "Astrovent" flapper.
Gary
Old Apr 4, 2009 | 01:27 PM
Paul L's Avatar
Paul L
Gary
I think yes.
Old Apr 6, 2009 | 03:57 PM
nutovette's Avatar
nutovette
Cruising
Roger
Thanks for all the info. I'll give it a try.
Old Apr 6, 2009 | 06:37 PM
mrvette's Avatar
mrvette
I"M not sure about how that 'Asstro Vent' system was supposed to tie in with the rear grills on either side of the gas filler, but they were opened and closed with the two levers on either side of the 'special' console trim plate, two buttons/levers either side up forward, flat spot on the little button/****....think it must have been a slip cable contraption....
Anyway, my '72 vert had the rear panels blocked off on the vertical panel on the stern of the hatch....they were cut along with the plactic to mount 6x9 speakers, years ago....
An a/c car had all that crap blocked off and a different trim plate, the inlets being blocked entirely on the driver's side kick panel...no airflow there at ALL, the pass side had a vacuum actuated flapper in there that had the opposite action as the one under the top section of that air passage/plenum coming off the wiper door area....suck on the line and one opened and the other closed...springs reversed the action when the vacuum was removed....
the above was all FINE for a T-top/ coupe....but absolutely a total waste of time for a convertible...as ASStro vent was totally silly with top UP or DOWN...
which brings up another thing, I blocked my intake flappers off, and so my a/c is on recirculation with NO 'fresh air' induction possible.....
There are OTHER modifications to the car coming up, with the up coming repaint...so maybe some pix will be forthcoming at some time, of various aspects to the job, AND the reasoning behind them....these are just body mods, nothing mechanical, this time round...
Old Apr 6, 2009 | 08:00 PM
Mike Ward's Avatar
Mike Ward
Completely incorrect. No connection with the two levers. Those opened thefloor vents in the kick panels.
Old Nov 16, 2019 | 01:08 AM
Gale Banks 80''s Avatar
Gale Banks 80'
Old thread new question. Does anybody know of a 1969 with out Astro Vent that did not have AC ? I have the Block Off Plates and yes it is a Convertible.
To Astro Ventalation
