81 carb cycling
Old Apr 5, 2009 | 09:11 AM
namvet6869's Avatar
namvet6869
Default 81 carb cycling
still havent solved carb problem. via the forum i did a check where you removed the ash tray and jump the two terminals that dont have a divider between them and turn the key on but dont start. i did that and it clicked one time and quit. should it not continue cycling?????????? seems like i remember it used to cycle continueous while it was running. i'm not hearing that now. could this be a place to start. it idles rough enough that it dies and runs rough until wot. namvet
