Small Block Engine Numbers
Old Jan 30, 2002 | 05:41 PM
Brian67Coupe's Avatar
Brian67Coupe
Default Small Block Engine Numbers
I just inherited a complete small block engine and could use some help interpreting the numbers. Casting number: 3970010 (350 with 2 or 4 bolt mains?) Pad - 2 numbers: 111201979 (1979 ?) and K0609CGC.
Thanks for the help.
Brian :seeya
Old Jan 30, 2002 | 05:46 PM
Tom73's Avatar
Tom73
Default Re: Small Block Engine Numbers (Brian67Coupe)
What you have is a '71 350/245hp used in the full size chevy and in the El Camino. This is indicated by the CGC suffix. The first number 111201979 would be the VIN deritive where the last 5 or 6 digits match the last of the VIN of the car that the engine was installed in. The other, K0609CGC, is the engine usage and it translates as K=engine plant (Vette engines come from the Flint plant, code V), 0609=asssembly date (Jun 9), CGC=usages as described above.
tom...
Old Jan 30, 2002 | 05:47 PM
lbell101's Avatar
lbell101
I show the CGC stamp only used in 71 on the 350 but not a vette engine. What is your block date code. It's just to the pass side of the distributor.
Old Jan 30, 2002 | 05:54 PM
Brian67Coupe
Default Re: Small Block Engine Numbers (lbell101)
Thanks Tom and Larry. The date code is K7. Brian
To Small Block Engine Numbers
