Vortec swap Dyno
Old Apr 6, 2009 | 05:58 PM
bytor's Avatar
bytor
Default Vortec swap Dyno
I took my vette to a local speed shop that was having a dyno day to see how my numbers look since my recent Vortec head swap. I made 2 runs including A/F measurements. I suspected I was a bit rich and I was. So I have some A/F tuning to do and some high RPM belt squeal to work on. I don’t think the numbers are too bad for my first project like this. I’m running an L-82 w/Vortec heads, ~10.1 compression Edelbrock Performer intake, Comp Magnum 270 cam and duels with stock exhaust manifolds.
1st run 275hp and 320tq
http://www.youtube.com/watch?v=R4feX15N9-E
2nd run 278hp and 320tq
http://www.youtube.com/watch?v=c2cbHZRMHnE
Old Apr 6, 2009 | 06:30 PM
'75's Avatar
'75
Pretty cool, what does that work out to for flywheel horsepower?
Old Apr 6, 2009 | 07:10 PM
bytor's Avatar
bytor
I'm new to this but I've been told that's around 305-315 for flywheel horsepower.
Old Apr 6, 2009 | 08:18 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Change the intake to a RPM Air Gap for another 10-15 HP. I got about the same HP/Tq as you did with this manifold and Sportsman II heads. I got around 285RWHP if I remember correctly with same cam and compression ration.
You are making good power, as for flywheel HP it is over 350HP
Old Apr 6, 2009 | 10:02 PM
bytor's Avatar
bytor
How much drivetrain loss are you including in your calcualtion?
Old Apr 6, 2009 | 11:41 PM
MotorHead's Avatar
MotorHead
My C3 loses roughly 22 % from engine dyno to chassis dyno
I know this because I have done it. Same goes for you, you can't measures net hp very well the only comparison you can make is your motor on an engine dyno ( gross HP ) and in the Vette on chassis dyno ( wheel HP ) .
The guy who gave you the HP numbers would be talking about Net HP numbers as in a C5 where you would have the Net HP from GM and then you put it on a chassis dyno. They have good tight drivetrains and only lose 12-15% max from Net Hp.
I have seen many ZZ4's ( 350 HP Gross ) on a chassis dyno they range 240-265RWHP
Old Apr 7, 2009 | 07:13 AM
worship79's Avatar
worship79
Nice numbers, would you happen to have a before-vortec dyno as well?
Old Apr 7, 2009 | 10:46 AM
bytor's Avatar
bytor
No, unfortunately not.
Old Apr 7, 2009 | 02:12 PM
Quil's Avatar
Quil
Is your car manual or automatic trans?
Old Apr 7, 2009 | 02:14 PM
bytor's Avatar
bytor
Manual,
Old Apr 7, 2009 | 04:01 PM
ED69ray's Avatar
ED69ray
not disputing your info but 22% is surprising
do you find much variation between auto vs 4 speed?
Old Apr 8, 2009 | 10:18 AM
bytor's Avatar
bytor
It would be interesting to see what a stock L-82 shows on a chassis dyno? Anybody got these numbers?
Old Apr 8, 2009 | 10:25 AM
7T1vette's Avatar
7T1vette
Approximately 5% less loss with manual tranny vs. older type of Hydra-matic box.
Old Apr 10, 2009 | 08:30 AM
bytor's Avatar
bytor
Anybody?
Old Apr 15, 2009 | 08:12 PM
JDRez42's Avatar
JDRez42
i took my 80 l48 to the dyno years ago i think all i had was headers and true duals put down 180hp 265tq at the wheel
Old Apr 15, 2009 | 08:24 PM
JustinD's Avatar
JustinD
Not to hijack but what kind of vortec heads did you use and what kind of pistons are in there?
Old Apr 15, 2009 | 11:01 PM
FRSTR90's Avatar
FRSTR90
Not trying to rain on anyones parade here, but you can not calculate drivetrain loss as a percentage... My explanation:
Example:
350ci. - 350 HP X .20 = 70 HP loss
572ci. - 700 HP X .20 = 140 HP loss
Why would a 572 lose twice the amount of HP than a 350ci? You only lose a fixed number of HP from your flywheel to your wheels...
To Vortec swap Dyno
Old Apr 16, 2009 | 07:22 AM
bytor's Avatar
bytor
Vortec 906 heads and I'm using my stock L-82 flat top pistons.
Old Apr 16, 2009 | 01:34 PM
74batmobile's Avatar
74batmobile
my car did 140whp/ 190tq
but my mixture was messed up and i had a leak from one of my headers.
guy who dynoed it said some were at 170/230 if i fixed it.
minds a auto l48
Old Apr 16, 2009 | 11:23 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Example:
Friction is the reason for most of the HP loss. The friction between gear surfaces, the friction between bearing surfaces, ect. With more HP you create more friction at all the contact points in the driveline so more power is lost. Loss due to fluid viscosity will remain pretty much constant but it is a much lower percentage of the total driveline power loss.
