134a conversion
Old Apr 13, 2009 | 06:44 PM
Dave Witman's Avatar
Dave Witman
Default 134a conversion
Converting a 73 big block a/c to 134a. What is required to be done with the dryer/reciever. Do I just need to replace it with a new unit or do I need to upgrade to something else. Dave
Old Apr 13, 2009 | 07:10 PM
Peterbuilt's Avatar
Peterbuilt
Default R134a
Haven't tried it myself but I saved this http://www.corvetteforum.net/c3/zwed...c/retrofit.htm PG.
Old Apr 13, 2009 | 09:45 PM
chvet73's Avatar
chvet73
That's good information above but your '73 has a VIR system. So what is said on that other post does not all apply.
There are a few options you can choose to do this. You would have to replace the VIR or rebuild it to convert to 134. All lines and parts need to be flushed. Compressor oil needs to be changed to 134 type. You can also get a VIR eliminator kit instead of dealing with the VIR. Most likely thats cheaper and easier. Ecklers and others have the kit.
On my own I upgraded to a 82 Evaporator and Accumulator. Then changed to a Sanden compressor. The results still were not waht I hoped for. This also needs custom hoses made. I had mine done at a local shop.
So now I am in the process of changing the Condensor to a crossflow type. I am just finished changing the blower fan to a C4 model from an '87. Much better air flow. When I'm finished we'll see how all this works.
So there is alot to consider in making the change. With the amount I've spent I'm not far from putting in an aftermarket model. That's something to think about too.
Hope all my ramblings help you.
Old Apr 14, 2009 | 09:56 AM
Dave Witman
OK that helps Thanks for the info. Dave
Old Apr 14, 2009 | 07:01 PM
doctorgene's Avatar
doctorgene
Look guys, I just put my system together and pumped it down. waited 30 minutes , put in shot of 134 oil, and two and one half cans of 134 and it's been cooling for the last 3 years. I guess I'm just not too smart, I read an article by the people who make 134 and they took 12 Co. cars, did what I did to mine to 6, flushed out 3 more and filled with 134, and took the other 3 and changed all the parts which you are talking about and filled. The 12 cars are all still cooling. Why don't you write the people who make the 134 and check this out. Doctorgene
Old Apr 14, 2009 | 07:06 PM
doctorgene's Avatar
doctorgene
P. S. My cars are a 1979, and 1980, an 1982 Two corvettes an a EL Camino Doctorgene
Old Apr 14, 2009 | 09:16 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Haven't done one yet myself, but according to Interdynamics, who happen to be a player in the business, this isn't exactly rocket science...
http://www.id-usa.com/how_to.asp
Hope that's worth something to someone.
TSW
To 134a conversion
