Distributor/Dwell help please!!
Old Apr 16, 2009 | 11:45 PM
CCrane65's Avatar
CCrane65
Put the old points back in and see if the problem goes away.
I bought a set of points from O'Reillys, their best ones, and couldn't even get the dwell set because the base plate kept flexing in the middle. Put the old ones back in and it was good to go.
cc
Old Apr 16, 2009 | 11:53 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Hey ************* CCRane is on to something here.
We had a customer in the shop around 4 months ago with a set of points he installed and a very sick running car!
The two contacts were only hitting on about 1/3 rd of the surface, the throw arm was bent.
Good idea and I forgot about this. I don't know where the customer got the points set, but we only use the Delco points sets I think the p/n is D103P.
Willcox
Old Apr 17, 2009 | 05:45 PM
RedAirRdstr's Avatar
RedAirRdstr
cc
Willcox
I will have to give this a try as soon as I get a chance, I bought the best stuff I could get from Napa, but half of that stuff says made in mexico now, so who knows
Thanks for the help,
Jeremy
Old Apr 17, 2009 | 07:33 PM
FB007's Avatar
FB007
Jeremy
Try a NAPA CS786
Old Apr 17, 2009 | 10:35 PM
Donald #31176's Avatar
Donald #31176
Originally Posted by FB007
Try a NAPA CS786
Use HD points with spring pressure 28-32 oz ( BW 112HP, Napa CS 786, Delco 112 or Accel 8140 point & condenser kit. The key to a good running points distributor is to optomize the ignition curve, use quality ignition parts and to correct excessive looseness.
Old Apr 18, 2009 | 12:31 AM
RedAirRdstr
Try a NAPA CS786
Napa CS 786 and condenser are what I bought, I think its probably more than the points but I'll swap in the old ones just to see what happens, I just wish I would have checked the dwell quick before I changed the points so I knew what the baseline was...oh well, its all in good fun
Old Apr 18, 2009 | 11:15 AM
CCrane65's Avatar
CCrane65
Your old points will retain their dwell setting as long as you don't turn the allen head screw or make any other changes.
cc
