71 current draw
Old Apr 15, 2009 | 01:06 AM
madmax396's Avatar
madmax396
Default 71 current draw
My 1971 454 auto has a current draw that slowly discharges the battery when the car sits for a day or so. What are the common places to look first? I did a search and only found for 1980.
Old Apr 15, 2009 | 02:15 AM
Peterbuilt's Avatar
Peterbuilt
Default Current Draw!
Try disconnecting the battery pos cable and put a test light between the cable and the battery, then pull 1 fuse at a time untill the light goes out. When the light goes out you have to trouble shoot that circuit. If you pull all the fuses and the light stays on then disconnect the pos from the alternator, you may have a bad diode. PG.
Old Apr 15, 2009 | 03:47 AM
QuicheLorraine's Avatar
QuicheLorraine
Yep that's the best thing to do for starters! You're isolating one circuit at a time while checking for current draw.
Old Apr 15, 2009 | 10:30 AM
madmax396's Avatar
madmax396
Thanks guys. Ill try that today and see what I can find.
Old Apr 15, 2009 | 05:39 PM
madmax396's Avatar
madmax396
Did both things. Pulled all fuses and light stayed on. Pulled the pos. wire off the alt. and light still on. What is there to try next? Help
Old Apr 15, 2009 | 06:04 PM
stellar's Avatar
stellar
you might have more than one draw or if the door was open was there a courtesy lite drawing? Did you add anything recently ? Change a radio maybe?
Old Apr 16, 2009 | 12:32 AM
Peterbuilt's Avatar
Peterbuilt
Default Gotta dig deeper!
Next your going to have to check the unfused circuits. Stellar asked a good question, did you add anything like a new radio? Do the hazard lights work OK? Has the horn been working properly? Do the parking lights and headlights work OK? Is the starter or solenoid causing the problem? Do you have a power antenna? You have to go through each system step be step.
PG.
Old Apr 16, 2009 | 08:56 AM
joewill's Avatar
joewill
how about your your alternator 2 wire plug, pull that and test your light.. also, your radio presets and clock will pull some current with the car sitting... you will need to get a milliamp tester and let us know what the draw is, make sure lights are off, key out, door closed.. 10-20 milliamp draw is ok, but 1000 milliamp draw is not.. if you pulled your fuses out and still have problem, then check your battery, it may just be old and time to replace.. else you have an unfused direct path to ground. any unfused direct path to ground should fry your harness and drain your battery in an hour.. so I doubt that is your problem.
Old Apr 16, 2009 | 09:01 AM
08vycpe's Avatar
08vycpe
The threaded post on the horn relay is hot all the time and has no fuse. It is protected by a fusible link.
With the test mentioned above start with the horn wires and then remove the wires connected to the horn relay stud and see if that is where the drain is.
Old Apr 16, 2009 | 09:26 AM
tommyleea's Avatar
tommyleea
Just for clarification. Do you use the positive cable for this test, or the negative cable for this test. Or does it matter? I have seen it mentioned both ways. Thanks
TommyJ
Old Apr 16, 2009 | 09:44 AM
DRIVESHAFT's Avatar
DRIVESHAFT
TommyJ
It really doesnt matter, but the negative cable is the safer way.
In a Vette though, accidental arcing is less likely than in "normal" cars.
Old Apr 16, 2009 | 10:00 AM
tommyleea's Avatar
tommyleea
That makes sense. Thanks
Old Apr 16, 2009 | 10:58 AM
madmax396's Avatar
madmax396
The car is new to me. It is a completely stock 71 454 AM/FM radio and NO power antena. Last night I fixed all the exterior lights (parking, headlight and turn signal). The headlight switch was bad too, so I replaced that. Now all the lights work appropriately.
The horn does not work.
The battery and starter are new from Napa, but it has the original GM alternator.
How do you test the alt. 2-wire plug?
To test the milliamp draw do you just disconnect the pos. battery terminal and connect the milliamp gauge to the battery and cable end?
Thanks everyone for your suggestions.
Old Apr 16, 2009 | 01:42 PM
SIXFOOTER's Avatar
SIXFOOTER
Use an amp meter instead of the test light as mentioned above to determine exactly what the draw is in miliamps. You can do this at the battery, ot at the alternator. The shop manual details how to test the alternator with an ohm meter, been a while so I won't try to explain it now. To determine if the alternator is causing the draw, unplug the 2 wire connector and disconnect the big red wire off the back, that will completely remove the alternator from the system.
Old Apr 16, 2009 | 05:31 PM
Peterbuilt's Avatar
Peterbuilt
Default Not Fixed Yet!
You removed all the fuses and disconnected the big wire on the alternator and the test light is still on, now unplug the 2 wire connector from the alternator, if the light goes out the problem is in the alternator.
You say there is a new starter. On the wiper motor there is a 3 plug connector and a seperate black ground wire, the other end of the wiper motor ground wire goes to a bolt that holds the starter on. The end of that black wire has a large lug and by mistake it gets attached the the starter pos wire, make sure that wire is on the starter bolt or on a bellhousing bolt.
I have a troubleshooting guide for the horn, I think it was published by Jim Shea but I don't have the link to it but if you need it pm me your email. PG.
Old Apr 17, 2009 | 09:37 AM
madmax396's Avatar
madmax396
I had the starter off a couple weeks ago and Im pretty sure that black wire isnt where you say it should be. I'll have to jack the car up and check again.
I seems as though after fixing all the exterior lights the other night I fixed the problem. My milliamp draw is only 13mA. I also replaced the headlight switch. Before to get the interior lights to work I had to wiggle the headlight switch ****.
Old Apr 17, 2009 | 09:53 AM
KB9GKC's Avatar
KB9GKC
Douglas in Green Bay
Old Apr 17, 2009 | 09:51 PM
joewill's Avatar
joewill
13 MA is good.... looks like you are good to go.... still don't know theroot cause tho'
again, if you had your starter hooked up wrong... you would have fried something real fast.....
To 71 current draw
