big blocks??
Old Apr 15, 2009 | 02:33 PM
skerky10mm's Avatar
skerky10mm
Default big blocks??
i just wanted to see if any one have seen a big block chevy in a c3 (not ls6). i really love c3's a 71 with a ls6 is my dream car. i am thinking of starting my own c3 and wanted to get some info first
Old Apr 15, 2009 | 02:58 PM
Derrick Reynolds's Avatar
Derrick Reynolds
St. Jude Donor '13-'15, '17 thru '22
Huh? Have I seen a BBC in a C3? Well, ....uh,....yeah, the last time I went into my garage. LS6 in a Corvette was one year only, 1971, and they only made a couple hundred of them (188 comes to mind, but I don't trust my memory since I have both CRS and old timer's disease). Chevy made at least a couple thousand big block Corvettes per year from '68-'74, so I don't consider them at all rare. What kind of info are you looking for?
Old Apr 15, 2009 | 03:09 PM
skerky10mm's Avatar
skerky10mm
i was looking for info on space. like would i be able to put a 540 bbc with a duel-quad set up? this is going to take a long time to build for me because im only 20 and cash doesnt grow on trees where i live lol.
Old Apr 15, 2009 | 04:01 PM
65747785's Avatar
65747785
Yaaaa big blocks. I have 2 of them, check out my albums. You will have to go with a higher hood though on your project if your going with the two 4 barrels. All shark big blocks had a low rise aluminum manifold. Except the L-88 and ZL-1 which used an older style factory high rise. Then they got the L-88 hood. My sons yellow 77 has this hood, but it's a small block 350. It's just for looks to go with his header side pipes.
You can put any cubic inch in. The outside of the big block is the same even if you go up to 572 cubic inches.
Old Apr 15, 2009 | 04:05 PM
skerky10mm's Avatar
skerky10mm
i dont have any problems with with going a cawl. i was planing on putting on on it any way. am im dumb going with a carb set up in stead of a fuel injection?
Old Apr 15, 2009 | 06:20 PM
baxsom's Avatar
baxsom
well that powerjection III FI system looks pretty cool and i was considering going to it until i dropped on my speed demon.
after that i am thinking the carb is fine.
Old Apr 16, 2009 | 09:49 AM
Gage's Avatar
Gage
What planet have you been living on the last 41 years??? While they are not a dime a dozen they have been around forever.
A 540 huh? You will never get any traction in a C3 without major mods, then you have lowered the value to the point where it doesn't make sense. The 454 in my 71 spins the tires in almost all gears so a 540 would be probably burn your tires to nothing in about a week
Old Apr 16, 2009 | 09:51 AM
skerky10mm's Avatar
skerky10mm
does any one have a duel carb setup?
Old Apr 16, 2009 | 10:31 AM
3JsVette's Avatar
3JsVette
I know this budget is above most peoples means but you may want to start here to get some ideas http://forums.corvetteforum.com/c3-t...oject-car.html
Old Apr 16, 2009 | 10:54 AM
2armor's Avatar
2armor
You'll need the tranny and rear end to handle all that too. Snowman obviously has crazy money to do that too. What an awesome car he built..
Old Apr 16, 2009 | 11:21 AM
Mike Ward's Avatar
Mike Ward
Is that where they fight each other with swords?
Old Apr 16, 2009 | 11:42 AM
skerky10mm's Avatar
skerky10mm
lol i dont thinks so
Old Apr 16, 2009 | 12:05 PM
TimAT's Avatar
TimAT
I have a BB in my 69. And I also have an Edelbrock C-66R manifold with dual Edelbrock 4 bbl carbs. It was under a lo-rise hood- NOT an L-88 style or BB hood. Lo- profile air cleaners are required.
As long as you stay with a 9.8 deck block and don't get silly with raised exhaust ports in the heads, it's a bolt in deal. Even with raised exhaust ports, I don't think it'd be a real deal unless the ports were .500 or .600 higher. And they might fit too with a little mod to the headers.
To big blocks??
