Reinstalling Engine
Old Apr 20, 2009 | 08:27 AM
Roarinbear's Avatar
Roarinbear
Default Reinstalling Engine
I pulled the short block out to have it rebuilt. Disassembled intake and heads in the car. I am planning on reassembling it on a stand with Edel. aluminum heads and intake. is there going to be a safe lifting point or should I install the heads and intake in the car? I figure it will be alot easier to assemble and adjust lifters on a stand, and then install it as an assembly. Looking for suggestions.
Old Apr 20, 2009 | 08:36 AM
Gordonm's Avatar
Gordonm
Install it all back on the engine. You can lift it by the heads or even a carb flange. A lot here me included do not like the carb flange but it does hold up. Much easier to assemble on the stand.
Old Apr 20, 2009 | 09:02 AM
Duke94's Avatar
Duke94
Install it all on the stand, MUCH easier.
Gary
Old Apr 20, 2009 | 06:35 PM
Roarinbear's Avatar
Roarinbear
I wouldn't hesitate lifting from the heads or intake on the cast set up. But wasn't sure if the aluminum was strong enough. Thanks Guy's
Old Apr 20, 2009 | 06:49 PM
midyearvette's Avatar
midyearvette
i have always used the chassis for an engine stand and just installed the short block in the car after i built it on the stand....but that's just me....
Old Apr 20, 2009 | 09:12 PM
tnovot's Avatar
tnovot
Putting everything together on the stand also lessens the chance of scratching a painted surface while leaning over it or dropping a tool or something on a fender.
If you are getting anywhere close to the age I am, it also saves your back so you will be able to straighten up when getting out of bed the next morning.
Terry
To Reinstalling Engine
