URGENT HELP: problem installing distributor
I need help. I have spent days trying to re-install the distributor.
I will try to explain as best as I can but I am in such a state that it is difficult to think straight!
It seems the distributor housing will not align properly into the engine block.
I put it in, and it doesn't just 'drop' in like everyone says. I can't quite for the life of me think how the housing could actually be bent, or what could be hitting. Its definitely not the oil pump shaft as it seems to line up perfectly.
I marked everything before I took it out. The distributor housing just refuses to go in straight.
Any suggestions? Would appreciate any help you may have.
I need valium!
worth a shot
The round bit at the bottom stops about just a little less than an inch from the intake manifold with the gasket in place. And the issue I am having is, the distributor doesn't look level.
Thanks for posting the video. I have watched that 10 times
, and I have rotated the oil pump drive shaft and it seems like its lined up perfectly.It is like there is something else interfering with the distributor from dropping in that last inch and I really can't think what.
How could the distributor shaft possibly be bent!
Its the original distributor from the motor. I stupidly pulled it out to install one of those petronix ignitors instead of the original points.
No need to tell me if aint broke, don't fix it.
Why why why didn't I listen to myself.
Thanks for your replies. I appreciate you all trying to help.
I really don't think it is the oil pump drive shaft.
Now that I think about it, when I first removed the distributor it was extremely difficult to get it out that first little bit. So whether there is some interference in the bores?
I appreciate any response. :o
pull the distributer straight up and look at the tab that goes into the pump.
use a long blade flathead screwdriver to make the slot in the pump point in the same direction.
we are going to assume that your distributer has no obvious problems.
or you would have noticed already.
Instead of just moving the distributor shaft in order to line it up with the pump shaft, you probably should start from scratch. Did you turn the engine to No1 TDC before removing the distributor, or was it just pulled out in the position that the engine last stopped?
I cannot believe I did not see that earlier. I have looked at 100 distributor pictures and stared at my one for hours and did not see it.
Thank you, THANK YOU!
Thanks again petes74ttop!!!
And for anyone installing a distributor there is really no need to 'bump the starter' to line up the oil pump shaft, it is very easy to use a long blade screwdriver to turn the oil pump shaft to the right position (well it is easy once the distributor gear is installed the right way up
cosmic
