Check My alignment specs please
Old May 3, 2009 | 07:23 PM
Bowerss2's Avatar
Bowerss2
Default Check My alignment specs please
got the car running today, Monday off to the shop for an alignment. This is what i was thinking after talking to people, what do youall suggest.
Front
Toe 0"
Camber .5 neg
Caster 2.75 pos
Rear
Toe 1/8"
Camber .75
Driving will be "spirited street" and some auto cross for fun.
Old May 3, 2009 | 09:10 PM
zwede's Avatar
zwede
Unless you have some stiff control arm bushings I'd dial in a hair toe-in up front.
Why only -0.5 camber front? I'd go -0.75 and more caster if you can get it.
Rear I'd stay at -0.5, that's where I've found even tire wear. The more neg camber you have in the rear, the worse it launches.
This is assuming you have modern tires, 17" or better. If you're still on 15" balloon tires I don't know if these settings will work.
