Choke Cable Installation
Old May 7, 2009 | 02:28 PM
daneichel's Avatar
daneichel
Cruising
Default Choke Cable Installation
I have a 1979 with a Holley 4160 carb that has a manual choke. The previous owner installed it but never routed a choke adjusting cable. I finally bought one, but I'm not quite sure where to route the cable through the firewall or where to mount the adjusting **** in the dash...I was thinking of just going through the firewall in the same place as the throttle and installing the **** below the hood opener. Any suggestions?
Old May 20, 2009 | 07:15 AM
daneichel's Avatar
daneichel
Cruising
For anyone that finds this on a search with the same question, I ended up running the cable through the rubber seal where the headlight vacuum tubes enter the cabin, and mounted the adjuster right under the hood opener.
Old Jan 11, 2022 | 05:53 PM
Lukemclaughlin's Avatar
Lukemclaughlin
4th Gear
Did you have to drill a new hole for the cable to go through the rubber seal or does the rubber seal pop out?
Old Jan 11, 2022 | 06:35 PM
MelWff's Avatar
MelWff
You are asking someone who has not been here in 13 years.
To Choke Cable Installation
