Electirc Fan / Push or Pull
Old May 14, 2009 | 01:34 PM
conway62's Avatar
conway62
Default Electirc Fan / Push or Pull
For those of you who have installed an electric fan setup, what is the preferred method? A push type or a pull type. For a big block with A/C, a duel or a single ?
Thanks in advance.
Ron
Old May 14, 2009 | 01:56 PM
SteveG75's Avatar
SteveG75
Dual SPAL pullers. Best setup available . Costly, but you get what yu pay for.
Old May 14, 2009 | 02:05 PM
Garys 68's Avatar
Garys 68
I installed a sigle fan that could be configured to push or pull. The manufacturer indicated it worked better pulling.
Old May 14, 2009 | 02:13 PM
73StreetRace's Avatar
73StreetRace
Pull type is always more efficient.
You can find good electric large single fans like Ford Taurus one, or mark VIII. These are enough for big blocks, they move a LOT of air !
Make a search on the forum with these names.
Remember that a stock alternator is not sufficient for such fans. They draw a lot of current
See CS130 or CS144 alternators too.
If you want to see my fans, click on "My corvette photos" on the left.
They are dual SPALS and they work great. I made the fan shroud myself.
More pictures here :
http://forums.corvetteforum.com/c3-t...-pictures.html
and here :
http://forums.corvetteforum.com/c3-t...l-chapter.html
Old May 14, 2009 | 08:30 PM
markdtn's Avatar
markdtn
Pull
I used dual C4 fans from a '90-96.
Old May 14, 2009 | 08:39 PM
gingerbreadman1977's Avatar
gingerbreadman1977
* i agree pull is more efficient over push
* one 16 inch is more efficient than two 10,s or 12,s
* i recommend a spal
Old May 14, 2009 | 10:15 PM
MN-Brent's Avatar
MN-Brent
I did Lincoln Mark VIII with CS144 to drive it.
Set-up costs approx:
CS144 (140Amp) from Napa: $130
CS144 harness + extra wiring + fusible link: $40
Lincoln Mark VIII fan: $80
Proliance 4 core Big Block rad(medium quality at best): $255
Fan Switch(200on 185off): $50
180 thermostat (Napa premium unit) ($30)
Tyco (Bosch equiv)75A relay $50
Wiring and resetable circut breakers misc: $50
Misc metal brackets: $40
Rad fluid 3 gallons(Prestone Extended Life green:$30
$755 total ballpark-not too bad!!
Old May 14, 2009 | 11:06 PM
conway62's Avatar
conway62
I guess the question here is to go Single or Duel fan setup. What have most people done with Big Block setups ?
Old May 14, 2009 | 11:39 PM
sharkman76's Avatar
sharkman76
Dual SPAL pullers on my car!! but just as important is a good thermostatic controller (sending unit and relay kit) however the Dual SPAL pullers taxed my charging system I had to upgrade there also.
Old May 15, 2009 | 01:08 AM
d555's Avatar
d555
I run a primary puller and a secondary pusher.
Offset, with adj. relays on both.
B-Cool Aluminum radiator
Runs 180 on a hot idle.
Old May 15, 2009 | 12:46 PM
7T1vette's Avatar
7T1vette
I'm still trying to figure out why anyone would spend that much money on a new radiator and electric fan set-up, only to have air sucked through just the diameter of the fan. Doesn't anyone buy/fabricate a shroud to draw air through the whole radiator? A simple shroud would probably increase cooling efficiency of the system by 40-50%! {Oh, pulling is more efficient than pushing, as the fan [itself] is not blocking/disturbing the inlet airflow.}
Old May 15, 2009 | 05:40 PM
d555's Avatar
d555
I don't know about anyone else but, I run a BBC all aluminum motor including
oil pan. It gives me the versatility to adjust for street use, drag strip use, with or without nitrous. I also run preheaters for both water and oil.
Too much heat loss can become a reality when between rounds at the strip. Consistency can be very important.
To spend a grand on cooling, to protect a very expensive motor, is cheap.
Now on the other hand, a 462" iron block BBC that I run in my 67 442 loves the twin pullers and fully shrouded aluminum radiator. But a much better heat sink. Works very well. Totally agree, that is the way to go.
IMHO
Old May 15, 2009 | 05:47 PM
pauldana's Avatar
pauldana
Yup... you correct, Here is a thread I just compleated, I run 2 Spal fans, a PWM, Full aluminun shroud and more... check it out, it may give you your answer... if not take a look at the pictures for the fan shroud.. p
http://forums.corvetteforum.com/c3-t...-shroud-4.html
Old May 16, 2009 | 01:43 AM
73StreetRace
Yes, sir I did it !
Old May 17, 2009 | 04:37 AM
gingerbreadman1977
you keep trying to figure it out then , because why would i spend money on a shroud when i can not get a higher temp than 185 without one.
barracading the back of a radiator with a shroud will certainly help your fans pull air over a broader area but also restrict airflow when cruising.
if your fan and radiator or sufficient enough to not need a shroud then why have one?
Old May 17, 2009 | 05:14 AM
73StreetRace
To solve this issue and get the best of two worlds, it is possible to build sorts of flaps on the fan shroud that will open automatically when the air pressure inside the shroud is sufficient.
But as you say, if your fan and radiator are sufficient, you don't need anything else.
However, some people may need something more efficient, like a shroud, especially with the high temperatures in Summer, a Big Block and/or some serious power
Old May 17, 2009 | 11:22 AM
MN-Brent's Avatar
MN-Brent
There are shrouds that have flappers. Closed at 0 MPH and start to open once cruising.
Dewitts comes to mind.
To Electirc Fan / Push or Pull
