I have a poly installed on mine but I will be changing it out before the body goes back on. It was one that didn't have the sleeve or washers with it and it just doesn't look or fit right on the mount.
Ok! I’ll probably fire the whole lot of you up with this one! I’m putting on my bullet shield right now, strapping in and oh. .. I’m painting a target on my back too!
I’ll start with Norm: Way back when Lassie was a pup, we installed poly on Norm’s car! Countless times of putting grease on the poly sway bar bushings did not stop the squeaks. Finally we just replace the entire poly for the standard parts and no squeaks, no grease!
On my own personal car years ago I installed Poly! Same issues and one A-Arm shot! Yes I was hard on this car too so I’m sure this added to the problems.
It has always been my “Personal Belief” (and you have to realize that Poly has been around a long long time.) that poly should only be run on cars that are going to be raced around pylons, road raced and or for someone wanting to just run the car hard on a back hills road. Every where poly is installed in a car tightens up the car and I agree that this is a good thing if handling is what you want. If I were racing a car there is no way I would use anything else.
However, it is also my thought that everywhere you replace a part that was designed to have give and movement you also sacrifice ride! A good example of this is the front A arm bushings! The bushing was designed to have movement and not be hard and fixed; something has to suffer from changing them out.
If I remember correctly on some vendor sites there are notes about the poly bushings being used for the snubber cushion? I have seen the rear end on a performance car actually damage the frame bracket from having a poly busing installed in the car. (on a stock car I doubt you could damage this bracket with poly). If this bushing was designed to be solid I would thing GM would have just bolted the rear end front bracket straight to the frame.
You also have to remember that I was raised in a Chevy dealership! I’m not GM brainwashed, but sometimes I think making a better mouse trap can be a down fall. Most of us are driving the cars to enjoy them and lets face it the cars do ride hard enough on their own. Maybe I’ve brainwashed myself and my employee’s and maybe I’m the nut here. . . But I would rather tell you what I think over just keeping my mouth shut.
I could keep going on, but to me and PLEASE remember, this is my belief and I’m sure there are plenty of people that will think I’m crazy. . . But it is just an opinion. Ok, let the guns sling!
Willcox
My thinking exactly. Many times I see guys get caught in catalog/internet/magazine fever where what ever is shown in a magazine(often sponsered by a parts supplier) is what is needed on their car. They dump $$ into these changes, many times they don't fit correct and most times they are not really needed for street driving. To each his own I guess.
I have had VBP poly mounts on that snubber for some 15 years, and over the last few months have noticed some clunks in the back end under my butt.....dunno the source yet, but I typically have to hit the gas in order to induce the sound....
busy with other things so not remembering to get under there and check it....did ONCE and tightened hell outta that main bolt...but no change....
pm me when you figure it out sounds like the problem im having
it does appear though that someone flipped the 'g' key upside down
REAR END FRONT SNUBBER CUSHION BOLT SET. Includes Upper and Lower cushions plus the bolt kit to install it. The cushions are rubber as original. It is subbested that you only install Rubber snubber cushions on your car! 0413
Some of the poly throw off the alignment on the diff because the dimensioning is off, just like the ES poly trans bushings.
Hmm ... funny you should mention this. I just installed the ES poly transmission mount, and it was significantly taller (like 1/2") than the one I pulled out. I had to put a jack under the transmission to install it where the old one slid right out. I just assumed this was because the old one had collapsed over the years. There is a preload on the ES bushing that squishes it down ~1/8", but it still seemed too tall. Now you've got me thinking I should pull it out.
I was going to check the angles on both the diff and tranny pinions before I put the driveshaft back in. Do you think I'm ok leaving the poly bushings if the pinions are +- 2° or so?
Just remember that eventually rubber WILL fail, or you wouldn't be replacing it now.
The only bushings that will NOT fail over time are solid metal like the aluminum ones offered from Guldstrand.
Yes, you're right. Crappy rubber bushings. Some of them only last 20-25-30 years. I'm writing GM a letter of complaint right now and that I want my money back.
On the trans mounts. This is not a new problem, it goes back at least 5 years since I found it. Sounds like the import ball joint deal that no one knows about- but that's another thread.
Use it if you like, me I have 1 ro 2 sitting here new in the box. They were at least .250 taller and I called ES about it. After getting the runaround, a tech finally told me they were not for the corvette or early camaro BUT no one ever changed the catalog. A few years later I figured they must have had it corrected and ordered another kit from Summit, same deal,same part.
Quality rubber mounts last a long time, given most of these cars now see less then a few thousand miles a year why not use them? I did use poly eng mounts from ES no problem and the trans mount from Prothane was very close in size to the OEM rubber.
Aluminum will also fail over time and exposure, ever see a body mount on the early C3s, they just broke down, looks like erosion.
I have installed the poly bushings on about 4 vettes now including mine "80" and have yet to hear anyone complain or have problems with them . I even installed them on my top mounts of my differential , Ron
Well, I think they are still unchanged. I'll give ES a call, but I'm not expecting much. Thanks for the heads up on the Prothane bushing.
These pieces are THICK and machined from better aluminum than was available when C3's were made. They will NEVER wear out in my lifetime.
Whether you drive your car or not, rubber, on the other hand, deteriorates from Day 1 just due to the ozone in the LA basin.
These aluminium discs help eliminate crossmember movement caused by large tires, high cornering loads and engine torque. And yes, you will make the ride a little harsher and transmit a little more noise into the cab.
Those pieces are probably machined from 6061 aluminum which has been around forever. They use this grade because its reletively strong and is easily machined. But regardless, aluminum corrodes just like steel, just much slower.
ok... i did not see anyone forwarding this problem with poly and definitely aluminum.... VIBRATION!! Rubber will help dampen vibration, the others will not... Poly is good for a-arms and other handling bushings, other than that go rubber only. I have been working on vibration for about 2 years now and have it almost all solved..,. I have read for days and weeks about this and would never recommend poly for motor mounts trans mounts and rear-rend mounts... unless you like BUZZZZZ///
