Poly Differential Front Snubber Bushings-Problems?
I added two fender washers above the mount and this provided the needed clearance and solved the problem. With the car on the lift, it wasn't difficult to remove the bolt and using a big screwdriver, pry the pumpkin away enough to slip in the two washers and reinsert the bolt.
This is a typical comment that I don't understand. All the parts are there.
Just as a diversion, I had the chance yesterday to drive with new front shocks and poly swaybar bushings. The front end felt very firm and solid compared with the old shocks and deformed rubber bushings. I am rather pleased.
busy with other things so not remembering to get under there and check it....did ONCE and tightened hell outta that main bolt...but no change....
Like many of the poly bushings they are a perfect solution to a non-problems, every marketing man's dream come true. Sham-wow forever!
What is an "st car"?
I saw that thread over in the C2 area. And the quote comes from JohnZ whom we all respect as a wealth of knowledge. I really don't have problems in that area at the moment. I'm going through my 1974 bit-by-bit for 35-year-old maintenance. Perhaps if Willcox will give me a tit-for-tat I can just exchange for rubber. But you know the shipping etc. to Canada is more than the product cost....
I’ll start with Norm: Way back when Lassie was a pup, we installed poly on Norm’s car! Countless times of putting grease on the poly sway bar bushings did not stop the squeaks. Finally we just replace the entire poly for the standard parts and no squeaks, no grease!
On my own personal car years ago I installed Poly! Same issues and one A-Arm shot! Yes I was hard on this car too so I’m sure this added to the problems.
It has always been my “Personal Belief” (and you have to realize that Poly has been around a long long time.) that poly should only be run on cars that are going to be raced around pylons, road raced and or for someone wanting to just run the car hard on a back hills road. Every where poly is installed in a car tightens up the car and I agree that this is a good thing if handling is what you want. If I were racing a car there is no way I would use anything else.
However, it is also my thought that everywhere you replace a part that was designed to have give and movement you also sacrifice ride! A good example of this is the front A arm bushings! The bushing was designed to have movement and not be hard and fixed; something has to suffer from changing them out.
If I remember correctly on some vendor sites there are notes about the poly bushings being used for the snubber cushion? I have seen the rear end on a performance car actually damage the frame bracket from having a poly busing installed in the car. (on a stock car I doubt you could damage this bracket with poly). If this bushing was designed to be solid I would thing GM would have just bolted the rear end front bracket straight to the frame.
You also have to remember that I was raised in a Chevy dealership! I’m not GM brainwashed, but sometimes I think making a better mouse trap can be a down fall. Most of us are driving the cars to enjoy them and lets face it the cars do ride hard enough on their own. Maybe I’ve brainwashed myself and my employee’s and maybe I’m the nut here. . . But I would rather tell you what I think over just keeping my mouth shut.
I could keep going on, but to me and PLEASE remember, this is my belief and I’m sure there are plenty of people that will think I’m crazy. . . But it is just an opinion. Ok, let the guns sling!
Willcox
I'm awaiting delivery any day now the same parts. I'm interested in replys also
