Vacuum ?'s inside
Old May 21, 2009 | 08:52 PM
73 454's Avatar
73 454
Default Vacuum ?'s inside
When i rebuilt the 454 i put in a larger cam. Now i don't have vacuum at idle. And my brake peddle goes clear to the floor and the head lights don't go up and down when they should.
I replaced all the brakes last summer so they're all good.
Do they make a vacuum can? Or booster? What have you guys done to help the problem?
Old May 21, 2009 | 08:59 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
you should already have a Reservoir,
that is exactly why I did not put a huge cam in my 454.
they make an electric vacuum pump, you might need to go that route.
however a lot of guys say they run big cam's with little to no problem.
to truely answer your question you need to put a gauge on,
and ensure you have no leaks. 69VETT
Old May 21, 2009 | 09:30 PM
7T1vette's Avatar
7T1vette
If you had no manifold vacuum at idle, the engine wouldn't be running. I suspect you have a big vacuum leak somewhere. How are you measuring the vacuum level? What vacuum lines have you disconnected and/or capped?
Old May 21, 2009 | 10:51 PM
73 454's Avatar
73 454
I just put the gauge on the carb, and when i gave it gas the gauge would go to the green.
And i don't think i touched any of the lines. I guess i'll have to look it over for a leak or something i missed.
Old May 22, 2009 | 03:32 AM
Danish Shark's Avatar
Danish Shark
You connected the gauge to ported vacuum on the carb. Connect it to the manifold port instead.
Old May 22, 2009 | 07:09 AM
wer2xu's Avatar
wer2xu
The most likely culprit for a leak is the supply line to the heater. For a 1970, this line is T'd into the supply line to the wiper door rely, that T is easily broken, and you would have a massive leak.
But I am not sure if a '73 works the same way.
Old May 22, 2009 | 05:47 PM
73 454's Avatar
73 454
ahhh, good point. I removed all the heat, so i'll need to double check it this weekend.
Old May 24, 2009 | 12:35 PM
73 454's Avatar
73 454
Is the vacuum tank the large black tube up front under the head lamps?
Old May 24, 2009 | 12:39 PM
DRIVESHAFT's Avatar
DRIVESHAFT
Your brake pedal going to the floor is a brake problem, not a vacuum problem.
Low vac to the brake booster results in a hard pedal.
Old May 24, 2009 | 12:43 PM
73 454's Avatar
73 454
Well that's interesting. I replaced the master cylinder/all calipers/pads/the smaller lines to the calipers/and bled them. The only thing i didn't replace was the booser
Old May 24, 2009 | 04:18 PM
DRIVESHAFT's Avatar
DRIVESHAFT
I can see why you would expect that everything brake related was good at this point, but there is air in your system somewhere.
To Vacuum ?'s inside
