Weird Tachometer Problem
Old May 28, 2009 | 10:37 AM
hap1971's Avatar
hap1971
Default Weird Tachometer Problem
Guys,
I'm running a 75-up style tachometer in my 71 Corvette.
I'm using a CS144 alternator out of a 1997 Deville, and I have the adapter cable w the resistor installed. I have an 8 gauge wire running from Bat+ to the battery itself, with a 14 gauge fusible link at the battery.
The factory Bat+ wire is also intact.
MSD 6A box w MSD tach adapter.
Power to the tach is from an ignition on wire from the fuseblock, and grounds for the tach and the filter are to the intake manifold.
If I unplug the regulator on the alternator, tach works perfect. (Without alternator charging of course)
If I plug in the regulator, the tach reads about 25% of engine speed, and eventually quits reading altogether. Also, if I turn on a blinker, the tach needle jumps about 500 rpm with each blink.
I have no idea what is causing this, any suggestions?
The last modification I did was adding the 8 gauge wire to the Bat+ to the battery, but it has worked correctly since then.
Thanks,
Richard
Old May 28, 2009 | 10:50 AM
7T1vette's Avatar
7T1vette
Your tach filter is 'dead'. It should be "smoothing-out" those pulses from the other equipment (if it is functional and if it is wired in correctly). You can do some searching in the archives for the diagram of the tach filter's contents and make a new one yourself; or you can just buy a new filter.
Old May 28, 2009 | 04:05 PM
RunningMan373's Avatar
RunningMan373
Old May 28, 2009 | 06:22 PM
7T1vette's Avatar
7T1vette
There you go! Two resistors and two capacitors from Radio Shack ($3-5 max), remove the guts from the cannister on your present filter, wire the new filter and install it in the cannister (I don't know if it needs to be 'potted', and put it back in the car. Great info in the above post.
Old Jun 22, 2009 | 12:28 PM
Dins74's Avatar
Dins74
7T1vette
Regarding the Tach filter - I have unbaribale motor noise (wine) in my 74 w/a new audio system w/ inline filters everywhere. The wine gets louder with the RPM. Could the Tach Filter be the suspect
Old Jun 22, 2009 | 12:38 PM
RunningMan373
'74s didn't come with electronic tachs, so no tach filter, unless someone changed to a 75 or later tach, and included the complete set up, including the tach filter into yours. Look to see if you have a tach drive distributor. if theirs a cable coming off horizontally from the tach shaft, you have a mechanical tach, so no filter.
Old Jun 22, 2009 | 01:18 PM
C3 4ME's Avatar
C3 4ME
the first thing stated is he's running a 75 and up style tach in his 71. I too would try the tach filter first since it's inexpensive, and then go from there.
Old Jun 23, 2009 | 12:55 AM
chvet73's Avatar
chvet73
I have 76 tach in my 73. Run same MSD. My tach runs from the MSD tach output on the box. With that output I'm sure you should not use a tach filter.
To Weird Tachometer Problem
