1972 Corvette Front Grille Help
Old Jun 1, 2009 | 07:41 AM
Fchaffee's Avatar
Fchaffee
2nd Gear
Default 1972 Corvette Front Grille Help
Are the Front Grille's completely chrome, or part chrome and painted black or ???? ... I am now reassembling a 1972 Corvette (E-Bay special) and I have one side that is "ALL" Chrome and one side that is Chrome & the inserts painted Black...
PLease Let me know....
Frank
Old Jun 1, 2009 | 09:05 AM
CCrane65's Avatar
CCrane65
The egg crate portion along with the vertical and horizontal inside flat parts of the bumperettes are painted a medium-dark gray similar to gun metal.
Then all of the leading edges of the egg crate are chrome. Scrape the paint off with a razor blade after the paint has set for about 15 minutes.
cc
Oh by the way, the paint is supposed to have some grainy texture to it.
Old Jun 1, 2009 | 12:30 PM
7T1vette's Avatar
7T1vette
The closest paint color to the original gray on the 'eggcrate' areas is a semi-gloss 'cast iron' paint. You can usually find some in the auto parts stores paint section. As mentioned, the easiest way to paint them is to strip all old paint (paint stripper is the easiest way), Spray a good 'bare metal' primer, then wait 20-30 minutes and peel paint off leading edges to reveal chrome. Allow proper cure time on primer. Spray cast iron color paint, then wair 20-30 minutes and do the paint peeling 'thing' again. You can save time by not using primer...but then you have to do it all again next year! P.S. You have to be very careful not to damage the soft paint when you peel paint off the chrome edges.
To 1972 Corvette Front Grille Help
