Alternator hookup
Old Jun 8, 2009 | 03:57 PM
Dr L-88's Avatar
Dr L-88
2025 Corvette of the Year Winner- Modified
2024 C2 of the Year Winner - Modified
2022 Corvette of the Year Finalist -- Modified
2021 C2 of the Year Winner - Modified
2021 C1 of the Year Winner - Modified
2020 Corvette of the Year (stock)
C2 of Year Winner (stock) 2019
2017 C1 of the Year Finalist
Default Alternator hookup
Anyone here used one of those "one wire" alternators? I have one for my 68 and would like to know exactly which "one wire" to connect to the alternator.
Thanks,
Rex
Old Jun 8, 2009 | 04:16 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
the correct answer is none of the above,
you and your car would be much better off,
using the OEM type 3-wire design alternator.
69VETT
Old Jun 8, 2009 | 04:44 PM
TimAT's Avatar
TimAT
However, to answer your question, run a new 10ga wire from the alt output to the hot all the time post at the horn relay. Be prepared to fight with battery charging. The one wire thing dosen't really sense the battery properly so it'll have a hard time keeping up with different loads on the electrical system.
Old Jun 8, 2009 | 04:59 PM
toddalin's Avatar
toddalin
I have a 1-wire 100-amp alternator and have had no problems with it. I simply connected the existing red "Batt" wire from the old alternator to the new alternator. While it is grounded through the case/engine, I also connected the existing black ground wire to the case. Hey, it was right there and couldn't hurt. I clipped of the plug for the field and lights and tucked those two wires back into the loom.
To Alternator hookup
