water pump choice
Old Jun 11, 2009 | 07:51 AM
markdtn's Avatar
markdtn
Originally Posted by timemender
...If you have the original water pump you should hang on to it for future restoration purposes......
Used to be you couldn't buy a new (stock) water pump, now they are everywhere. I'd buy a new one and hang onto the old.
Old Jun 11, 2009 | 09:34 AM
dburgjohn's Avatar
dburgjohn
Default who's the boss?
does anyone know what the phrase "With raised boss for upper heater outlet". we pulled up the pictures on the part store computer but I can't see any difference
Old Jun 11, 2009 | 09:54 AM
Mike Ward's Avatar
Mike Ward
Early C3s had a unique pump with a smooth upper surface on the casting. Later C3s (72 and up?) had a different casting with a pronounced bump on the top with a flat upper surface. This bump was then drilled and tapped and was intended to be usable as port for a pump bypass like on a BBC. On Corvettes, the boss was blocked with a plug. The photos above by Dustup7T2 show this threaded boss.
Hope this helps.
Old Jun 11, 2009 | 10:24 AM
dburgjohn's Avatar
dburgjohn
Default OH, I finally understand
This thing. Since it talked about heater hose, I kept looking at the heater hose plug on the side
Old Jun 13, 2009 | 05:03 PM
dburgjohn's Avatar
dburgjohn
Default ASC Pump
so I go to the local Autozone and ask for the new 29.99 Duralast stock pump. I even give the store's part number (looked on net). Clerk brings me the box (right number on box) but when I open it up, the pump looks aluminum. I can tell it is the right pump, but aluminum. Three times I try to tell the clerk I don't think this is the correct pump but he tells me it is. I pay and leave. Later on the net I see this is a ASC aluminum pump for my car. Autozone does not even carry this pump, found it on Advanceauto's site for 108.99. My guess is that one company manufactures a lot of different pumps and needed to fill one more box than they had stock pumps. It will look good on my engine. Somtimes fate smiles at you as opposed to sneeking up behind to break wind.
Old Jun 13, 2009 | 06:06 PM
doctorgene's Avatar
doctorgene
dburgjohn, some people have all the luck. 30.00 won't buy the shipping today. What AutoZone store was that. LOL Gene
Old Jun 13, 2009 | 06:30 PM
dburgjohn's Avatar
dburgjohn
Originally Posted by doctorgene
dburgjohn, some people have all the luck. LOL Gene
If I really had luck, I would not have needed a water pump <G>
