Heads / Manifold question???
Old Jun 9, 2009 | 06:24 AM
RunningMan373's Avatar
RunningMan373
Default Heads / Manifold question???
I've got some new heads, edelbrocks. Also, an edelbrock 2101 manifold. The heads have water passages front and rear. The manifold has water passages center and front. Is this normal, how do the heads stay cool??? seems like there would be no flow through the head???
By water passages, i mean the ones next to the intake runner ports, the ones sealed by the intake manifold gasket.
Old Jun 9, 2009 | 07:20 AM
Ganey's Avatar
Ganey
The intake has a water passage in front. Heads are same both sides.
The intake center has a heat riser passage to heat carb & is used in some for heat for the choke.
Old Jun 9, 2009 | 07:29 AM
Ganey's Avatar
Ganey
PS Note the front of the engine is higher than back & as you know heat rises.
Old Jun 9, 2009 | 03:53 PM
RunningMan373
ttt
Old Jun 9, 2009 | 03:58 PM
71_S-Ray's Avatar
71_S-Ray
The cooling passages in the heads/block are only in the front. GM put ports on each end of the head so the head can be interchangeable (left to right; right to left). No need to buy left or right side head.
Old Jun 9, 2009 | 04:16 PM
RunningMan373
Thanks,
So the center cooling passage in the manifold won't fill with water? or is there a internal link between the front cooling passage and center cooling passages in the manifold, because there's no center cooling passage in the heads?
Old Jun 9, 2009 | 04:28 PM
Ganey's Avatar
Ganey
There isn't a center intake cooling passage, it's for exhaust heat - see post 2.
Old Jun 9, 2009 | 05:27 PM
RunningMan373
So that's different from EGR?
Old Jun 10, 2009 | 08:09 AM
Ganey's Avatar
Ganey
Yes. Carb heating to help vaporize the fuel esp. in cold weather has been used for a long time.
EGR, Exhaust Gas Recirculation is an emissions control, lowers peak combustion temp.
"2101" does not have EGR.
Old Jun 10, 2009 | 01:19 PM
RunningMan373
So it's just a sealed passage, with air in it, no feeds from anywhere? like exhaust or water? sealed on both sides by the intake gaskets?
Old Jun 10, 2009 | 02:07 PM
Ganey's Avatar
Ganey
The center heat passage gets exhaust from the heads.
For performance many of us block it off.
Old Jun 10, 2009 | 02:15 PM
RunningMan373
Alright, thanks. It looks like the heads i got have no provision for the exhaust gasses to get to this area.
http://www.edelbrock.com/automotive_...e-street.shtml
Old Jun 10, 2009 | 02:39 PM
Scott Marzahl's Avatar
Scott Marzahl
Correct, those do not have heat crossover provisions. If you are running a Q-jet, you'll need to convert to an electric choke since that crossover is what heats up your choke.
Old Jun 10, 2009 | 02:56 PM
RunningMan373
That was what i thought,, do you know if there are elecrtic choke retrofit kits available that will fit a Quadra with a divorced choke?
Old Jun 10, 2009 | 03:26 PM
vettesbydesign's Avatar
vettesbydesign
You have a favor coming,so I have a nice Demon 750 VS w/electric choke for you for 200.00 shipped.
I have no clue about the retro fit elec choke for the "Qs".
Old Jun 10, 2009 | 03:44 PM
Scott Marzahl
Yes there is, Lars had sent me the info at one time so I need to look for it. Maybe its in Barry's stuff up top in the sticky.
Old Jun 11, 2009 | 03:11 AM
RunningMan373
Thanks for the offer, but i'm reaching my spending limmit on this build, plus, i want to stay with the Quadrajet. Now, if i can just find a place to do the work.
To Heads / Manifold question???
Old Jun 11, 2009 | 03:14 AM
RunningMan373
Just put a second offer in on my dream house,, short sale,, it's not a down market for everybody!!! may solve itself!
Old Jun 11, 2009 | 01:07 PM
TopGunn's Avatar
TopGunn
http://www.carburetion.com/quadrajet.asp
Old Jun 11, 2009 | 11:07 PM
Scott Marzahl
In Summit the electric choke is part number EDL-1932.
