emissions removal
Old Jun 9, 2009 | 01:32 PM
al@impactcycles's Avatar
al@impactcycles
5th Gear
Default emissions removal
hi, i have an 81, exactly how much of the smog equipment and vacuum jungle can i remove without changing carb or dizzy..the air pump is still on but running no belt....i just want to clean up the engine bay and maybe elliminate some vacuum issues i alredy seem to have...we dont have smog laws here.
Old Jun 9, 2009 | 07:28 PM
2box's Avatar
2box
All You need to do is to remove and plug.... The hardest part to plug is the exhaust atleast on my 79 it was that easy/ But I ended up putting it back in the car before the smog check anyways...Good luck
Old Jun 9, 2009 | 11:00 PM
larryg3's Avatar
larryg3
i took the pump off my '81 and removed the air injector tube from both exhaust manifolds and welded the holes. lokks much cleaner and no prob. with the carb.
Old Jun 10, 2009 | 07:30 AM
jb78L-82's Avatar
jb78L-82
If you have or plan on running true duals with no cat, you may want to consider McJack's shorty headers which are a direct fit to a stock OEM exhaust and are dimensionally an exact fit to the OEM cast iron manifolds, no modifications required at all to make them fit to stcok type dual pipes that hook up to the cast iron ramhorn manifolds, but they are pricey. I love mine which look great, sound much better than the ramhorns, fit perfectly, and have no clearance issues in the engine bay or with the road. Just an option!
Old Jun 11, 2009 | 01:19 AM
larryg3's Avatar
larryg3
the '81 came with ss headers. just take out the air tubes and weld. cheap and works great.
To emissions removal
