blower fan
Old Jun 9, 2009 | 11:23 PM
corvette.75's Avatar
corvette.75
8th Gear
Default blower fan
My blower is not functioning correctly, the fan only turns off when the switch is in the center position, the blower motor recieves all the correct voltage, but the switch is operating in the wrong position, replaced the switch, is there a relay or something that switches the voltage to the blower motor and where would it be located. help please
Old Jun 10, 2009 | 01:04 AM
Peterbuilt's Avatar
Peterbuilt
Default Need more information.
Welcome to the forum from another "Redneck", do you have A/C or Not? PG.
Old Jun 10, 2009 | 03:54 PM
corvette.75
8th Gear
Default blower fan
Hey sorry about the shortage of info, yes I do have a/c. I hope my post wasn't to confusing, 75 vette L-82
thanks,
gerald
Old Jun 10, 2009 | 03:57 PM
corvette.75
8th Gear
Default blower
petes74ttop,
I did not realize that you were here local, thanks for the response
Old Jun 10, 2009 | 04:07 PM
justanotherdoe's Avatar
justanotherdoe
On my 76, there is a relay to activate the highest blower speed, and some resistors that control the lower speeds. Both the relay and resistor bank are located at the top of the firewall in the engine compartment on the passenger's side (top of the ac/heater coil).
Sounds like either an open resistor, or open wire from switch to resistor (or resistor to blower).
Fan doesn't switch off completely until the console control is turned from MAX AC to Off.
Most of the Corvette suppliers have year specific wiring diagrams. It pays to have one.
To blower fan
