Muffs wont budge
Old Jun 10, 2009 | 05:07 PM
MNTWINS33's Avatar
MNTWINS33
Default Muffs wont budge
im trying to get these off...more W-D40? one of the mufflers i can flex up and down but i cant pull it off....
Old Jun 10, 2009 | 05:33 PM
Gordonm's Avatar
Gordonm
Heat is your friend on stuck pipes.
Old Jun 10, 2009 | 05:38 PM
Attfay Elleybay's Avatar
Attfay Elleybay
A muffler shop wouldn't charge too much to just loosen them would it?
Maybe try driving it till it warms up, then use oven mitts to pull off the mufflers.
Old Jun 10, 2009 | 06:29 PM
CCrane65's Avatar
CCrane65
Go to Home Depot or Lowes and buy a BernzOmatic torch and heat up the area where it was clamped.
cc
Old Jun 10, 2009 | 06:50 PM
mint79's Avatar
mint79
clamps make a indent, air chisel, or cut carefully with a dremel tool.
This will open up the pipe, off she comes!
Old Jun 10, 2009 | 07:06 PM
MNTWINS33's Avatar
MNTWINS33
yeah a friend came over a nd told me the same thing but i dont have one...so i guess im going with the heat treatment
Old Jun 10, 2009 | 07:46 PM
7T1vette's Avatar
7T1vette
Sawz-all, new mufflers, some tubing and a welder.
Old Jun 10, 2009 | 10:37 PM
mtcraigco's Avatar
mtcraigco
+1
Was dropping the exhaust this past weekend on my 79, couldn't get the pipes separated, went to lowes and bought a $90 sawzall, pipes were off in less time than it took me to unpack the saw.
Of course if you're planning on putting that system back on, that may not be the best idea.
Are the pipes really worth saving??
It was ridiculously easy though! Where were sawzalls 20 years ago??
Old Jun 10, 2009 | 10:48 PM
MNTWINS33's Avatar
MNTWINS33
Originally Posted by mtcraigco
+1
Im not saving the pipes...im putting new 2.5s soon
Old Jun 10, 2009 | 10:53 PM
mtcraigco's Avatar
mtcraigco
Sawzall dude. Unbolt them at the manifold and then drop the hangers and cut about a foot behind the crossmember, they'll come right out in two pieces each side.
Get a sawzall that lets you mount the blade with the teeth pointing UP, this makes it easy to do the cut, just slow down when you get close to cutting through as you will be close to your floorpans
I got a Dewalt for 90 bucks and wish I had bought one 10 years ago!
Old Jun 11, 2009 | 04:18 AM
cosmicvette's Avatar
cosmicvette
sawzall - stainless hooker sidepipes, never play with annoying under car exhaust again.....worked for me
Old Jun 11, 2009 | 07:36 AM
not a '76's Avatar
not a '76
air cut-off wheel cutting down the pipes the long way.
Old Jun 11, 2009 | 08:23 AM
mrvette's Avatar
mrvette
+1
Milwaukee, 30 years ago, got stolen, went to a variable speed model....25 years ago, some daze you just need IT and nothing else will quite do...
Old Jun 11, 2009 | 07:07 PM
1nicecorvette's Avatar
1nicecorvette
thats what i just did for my new flows..
To Muffs wont budge
