Air conditioning question
Old Jun 11, 2009 | 05:30 PM
MattP51's Avatar
MattP51
Default Air conditioning question
If the ac sytem has not been touched for 5 years and there is still pressure in the system, is it safe to say there are no leaks?
Old Jun 11, 2009 | 06:18 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
No. only means it still holds some pressure, not the high pressure you need for the freon.
evacuate the system and do a static vacuum leak back test.
Old Jun 11, 2009 | 06:39 PM
7T1vette's Avatar
7T1vette
I take it that you depressed one of the check valves and you got a spray of Freon. In that case, it says that your system is sealed well and may be operational. It all depends on how much [static] pressure is in the system. With any system pressure, there should be no problem with turning it on; you can be certain that there is adequate lubricating oil and that there is no moisture in the system. Try it out....see what happens. The most you might need is a bit of a recharge.
Old Jun 11, 2009 | 08:20 PM
joewill's Avatar
joewill
if there is pressure after 5 years then it is at worst a slow leak and you can probably get by with a recharge to top it off that will last a couple of years... alot cheaper than the labor to evacuate, find and fix any small leak, plus parts, and recharge , with oil charge, totally from empty...
those evacuators that suck up and store the freon ( whatever R-xx it is) are not cheap and shops charge alot to use it...
of course you can't legally dump freon into the atmosphere ( save the ozone layer so you don't get skin cancer ) so if you do have a leak you are obligated to spend the big bucks to fix it....
thanks to big brother for watching over us....
Old Jun 12, 2009 | 08:00 PM
MattP51's Avatar
MattP51
thanks bros
To Air conditioning question
