summertime...new carburation?
Old Jun 14, 2009 | 09:03 AM
elle88's Avatar
elle88
Default summertime...new carburation?
I took a while to get a good carburation a couple of months ago...idle mix and jetting , but due to hot wheater , do I need to retune?
the idle speed has passed from 1000rpm or less to 1100 or slightly more.
I haven't check the plugs yet but I'm sure that they are not so clean as before.
advises are welcome.
-take the idle back to 1000rpm with the idle mix screws?
-rejet the carb ? Holley DP 800 with 72 prim jets and 78 sec jets now
Old Jun 14, 2009 | 11:44 AM
elle88's Avatar
elle88
no inputs?
Old Jun 14, 2009 | 11:56 AM
DaJesterMan's Avatar
DaJesterMan
your carburator is tuned to the ambient conditions (air density and temperature) that were present when you set it. I guess the real question is, were the conditions when you tuned it significantly different than now? (ie: 40 deg F to 110 deg F)
Old Jun 14, 2009 | 12:09 PM
elle88's Avatar
elle88
I tuned the carb in fresh spring (70 F ) , now it's more like 90 F.
is it usual to rejet a carb 2 jets down when hot temps come?
Old Jun 14, 2009 | 12:17 PM
DaJesterMan
not unless your precisely tuning your AFR with a wideband oxygen sensor or racing...
short answer: you should be good if your carb was tuned properly before...
Old Jun 14, 2009 | 12:46 PM
7T1vette's Avatar
7T1vette
You might need to adjust the choke and/or fast idle speed adjustment for better "start up" behavior...but there shouldn't be any need to re-jet unless you have some other system problem [i.e., vacuum leak, etc.].
Old Jun 14, 2009 | 12:52 PM
C3 Stroker's Avatar
C3 Stroker
Tuning is always specific to weather conditions.....I generally turn back the curb idle on my Holley (Quick Fuel) about 100-200 rpms in the summer due to the same rise you are getting. No need to re-jet if you are tuned OK for the summer. In the fall or winter, you may have to increase the idle back higher, as conditions change again.
I only experience this with Holley carbs (?), Edelbrock carbs hold their tune and don't seem to change.
Old Jun 14, 2009 | 03:08 PM
elle88's Avatar
elle88
OK
so to readjust the idle speed ,not the idle mix ( 2 screws)
I supposed that being the air hotter in summer is also less dense , so the A/F mix tends to be rich. the theory should be this...
I'll do a test with a vacuum gage connected to the intake and see if the mix requires to be leaner or not. if not , I'll simply readjust the idle speed
thanks
To summertime...new carburation?
