Permissible Upper Steering Shaft Play?
Hopefully your problem is in the upper bearing and not a fatigued jacket.
The upper bearing is part of the column bearing housing. It was pressed in place and then a thin die cast lip on the housing was spun over to retain the bearing. You can take a look at things by removing the steering wheel, hub, locking plate, and pulling the turn signal switch out of the column far enough to view the upper bearing.
You can find fairly complete instructions on disassembly and repair of the standard steering column by going to Terry Rudy's www.corvettefaq.com websight.
Click on Jim Shea's Steering Papers
Click on Corvette Steering Papers
Scroll down to the Std Strg Column 69-79 Section
Download the Std Strg Column 69-79 Disassembly & Repair Papers #1, #2, and #3
Download the Std Strg Column 69-79 D&R Pics #1 & #2
The Papers and Pics are available in word.doc and pdf format.
Good luck,
Jim
