engine miss
Old Jun 17, 2009 | 01:04 PM
Sho'nuff's Avatar
Sho'nuff
Default engine miss
Well im out of ideas. My stock 76 has an engine miss at constant speeds. When i give it some gas to speed up, it acts like i let off a little and get back on it. I have new plugs, wires, hei ignition module, rebuilt carb. Beginning to think something mechanical like wiped out cam lobe? anyone have an idea before i put it in the shop? Timing appears to be ok also.
thanks
Old Jun 17, 2009 | 10:07 PM
SH-60B's Avatar
SH-60B
That could be two separate issues. When you step on it to speed up and it actually slows, could be an inadequate accelerator pump shot.
A miss at constant speeds, check the valve springs and do a leak down test, or even just a compression test. Run the motor with a vacuum gage tapped to the manifold vacuum and observe the readings driving down the road (I have duct taped a vacuum gage to the windshield a few times).
Simple tests like these can help alot with diagnosis of a problem.
Old Jun 18, 2009 | 07:55 PM
Lotadoh's Avatar
Lotadoh
True. Hook a vacuum gauge up and see whats happening. This site will give you differnet scenarios of problems found with a vacuum gauge.
http://www.secondchancegarage.com/public/186.cfm
To engine miss
