gas gauge wrong
Old Jun 18, 2009 | 06:09 PM
377's Avatar
377
Default gas gauge wrong
the gauge reads say 1/2 tank when I drive it goes to E than back up too 1/2 whats up any help thanks
Old Jun 18, 2009 | 07:53 PM
manofsteel1's Avatar
manofsteel1
I'm pretty sure that it ai caused by the sloshing of the fuel when you stop and go. Mine does that too but then it settles down. That when I'm sure thatis how much gas I have. My fuel guage is off by almost 1/8 of a tank. So I do not go below a quarter a tnk of gas.
Old Jun 18, 2009 | 08:02 PM
...Roger...'s Avatar
...Roger...
If it reads correctly when sitting still, then the dampener inside the gauge around the needle is dried out and allowing the needle to respond to the tank sender signal too quickly.
Old Jun 20, 2009 | 09:09 AM
377's Avatar
377
it reads incorrectly when sitting.I think its the sending unit before i owned the car somebody put a gas tank in it and i dont know if the sending unit was changed.
Old Jun 20, 2009 | 09:40 AM
...Roger...
Check this out.
http://willcoxcorvette.com/repairand...lp.php?hID=276
or this
http://forums.corvetteforum.com/c3-t...g-68-76-a.html
Old Jun 20, 2009 | 11:33 AM
7T1vette's Avatar
7T1vette
Either the slider rheostat on the sending unit [in the tank] is going bad or there is a fault in the gauge wiring (break in the sender wire or break in the grounding) for that unit. It could also be corrosion on a ground or signal wire connection.
Old Jun 22, 2009 | 05:27 PM
377's Avatar
377
thanks for the info .
To gas gauge wrong
