Calipers
Old Jun 20, 2009 | 04:07 PM
grassman's Avatar
grassman
7th Gear
Default Calipers
Is this a stainless steel sleeved caliper. Thanks
Old Jun 20, 2009 | 04:21 PM
mrvette's Avatar
mrvette
NO, I see no silver end to the bore edge, and the pitting/rust on the sides say NO also....
you can get stock caliper replacements locally, but I recommend O ring installs, VBP is one source....but shipping calipers is almost as much as the kits alone...
Old Jun 20, 2009 | 04:25 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
I agree, hard too see, but no sign of a sleeve.
Old Jun 20, 2009 | 04:32 PM
grassman's Avatar
grassman
7th Gear
Is this what I need then to do the conversion to O ring style
Old Jun 20, 2009 | 04:37 PM
grandmastercorvette's Avatar
0grandmastercorvette
Former Vendor
YES, but do not forget to add the tool to hone the cylinders of the calipers and get them free of pits and grooves.
"DUB"
Old Jun 20, 2009 | 04:48 PM
grassman's Avatar
grassman
7th Gear
Thanks for the help. Is it better to do it this way or just replace with lip seals
Old Jun 20, 2009 | 06:00 PM
Former Vendor
That is a touchy question with me. I personally do not like the O-ring seals because they were not use from the factory. They are used to compensate (as I understand it) for other issues that MAY be out of tolerance in bearings and rotors.
Remember I do this for a living...repair and restore Corvettes. I can not change a part of the brake system unless I have documentation that shows that the O ring designed calipers are as equal to the original lip design seals. AS of yet, I have not seen any information on this. Regardless if they have been out for a long time and many people swear by them and NEVER had a problem with them....I just can't do it. Liability reasons...if you can understand that.
You can make your own decision, but if you are going to use the lip design seals be careful not to tear it while installing it because there is a special compressing tool that makes the installation easier. I have them but oddly enough , I don't use them anymore. It is more expensive for me to rebuild calipers for my customers than it is for me to buy rebuilt ones. MY labor and the cost of the kit makes it not an option. Not saying that I can't rebuild them, just not cost effective.
"DUB"
Old Jun 20, 2009 | 07:38 PM
Paul L's Avatar
Paul L
Just buy re-rebuilt calipers with SS sleeves. Autozone, NAPA, etc.
Old Jun 21, 2009 | 03:25 AM
Ronaldo's Avatar
Ronaldo
This is a SS sleeved caliper
Old Jun 21, 2009 | 08:04 AM
TopGunn's Avatar
TopGunn
Lip seal installed in S/S caliper, 2 years old. I just changed them to "O" ring style yesterday.
Old Jun 21, 2009 | 06:12 PM
Former Vendor
Top Gunn,
Yes, I see that alot. From what I have found is that is caused by several factors due to the crappy design GM created for a brake system. I wrote crappy only because I am comparing it to the later design brake system which is better.
Ususally caused by cars sitting for long periods of time and not being driven or not having the brake pedal pressed on a frequent basis.
Dirty fluid, in conjunction with bearing play and rotor run-out not within specs.
These brake systems are TOUCHY when it comes to working without problems. But they work great if within design parameters. And they do require regular servicing and inspection. It is the nature of the "beast".
Top Gunn, I hope your new calipers and brake system works for you.
I am just waiting for the next generation of muscle car engineers to come up with a way to retro fit our cars with a mag-lev type set-up that they have for the european trains what will allow us to due away with fossil burning engines and use four of these mag-levs for power and braking and still be attached to each wheel. So we are still free to drive....anywhere. You never know.
"DUB"
Old Jun 21, 2009 | 08:05 PM
grassman's Avatar
grassman
7th Gear
So even I do not have the ss calipers I can still get that kit that I posted above and it will convert over to o ring without ss calipers. I also saw I could just get the o ring pistons separate and the o rings separate instead of all the new bolts and stuff I do not really need in that big kit. Or just wait and save for new already built calipers. I guess thats what everyone goes through questioning those decisions. LOL
Old Jun 21, 2009 | 08:57 PM
72LS1Vette's Avatar
72LS1Vette
You will still need outer seals, probably new bleeders, new brake pad pins and cotter pins, so there isn't much of the O-ring kit that you don't need. Those bores look like they might not even be able to be honed enough to be rebuilt. The most cost-effective thing to do for right now is to use those calipers as cores and buy some rebuilt SS-sleeved calipers from a national chain. They only cost ~$50.00 each. When they start to leak in a few years buy the O-ring kit and rebuild them and then they should last for quite a while.
Rick B.
Old Jun 21, 2009 | 09:12 PM
grassman's Avatar
grassman
7th Gear
Sounds good that is kind of where I was leaning but not quite sure. Just wanted to start driving this thing been sitting too long. I know there is more work to do but got to start somewhere. Thanks
Old Jun 22, 2009 | 07:28 AM
TopGunn's Avatar
TopGunn
Originally Posted by grandmastercorvette
Top Gunn,
"DUB"
Thanks for the insight. Crazy stuff I guess. I don't have any proof the "O" rings are better, I thought I'd give them a try and see how they worked out. The lip seals both leaked after a pretty short time which was a little suprising to me . I drive the car a couple time a week but it does sit all winter like most of our cars in the snow belt so as you say maybe that's the cause. See what happens with these I guess.
Old Jun 22, 2009 | 01:08 PM
jsholm2's Avatar
jsholm2
I went with the o ring style. I had ss sleeved calipers so I just cleaned them up and painted and ordered the o ring kits. Worked great!
Old Jun 22, 2009 | 01:51 PM
Mike Ward's Avatar
Mike Ward
"DUB"
You're joking right?
To Calipers
Old Jun 23, 2009 | 12:11 AM
7T1vette's Avatar
7T1vette
Heck no! Superconductivity at 100F is just around the corner....
Old Jun 23, 2009 | 12:17 AM
427V8's Avatar
427V8
C6 the C5 of tomorrow
I highly recommend you replace the flexible rubber lines if you are replacing the calipers. the lines have a finite life expectancy and can cause weird problems when they fail. Now is a good time to replace them!
Old Jun 23, 2009 | 07:30 PM
grassman's Avatar
grassman
7th Gear
Thanks 427V8 I was planning on doing that kind of messed the one up I was trying to take off and thought might as well do all of them when I do the calipers. If its not one thing its another. LOL
