Crankcase Ventilation Help
Old Jun 22, 2009 | 11:48 AM
Fishndude's Avatar
Fishndude
Default Crankcase Ventilation Help
Well I blew another intake gasket and now dribbling oil out the front seal.. I just replaced the intake gasket because I was leaking oil out the rear. Both times the engine builder and I used permatex in the front and rear instead of the supplied cork gasket and when I did it, I made sure it was totaly oil free before applying it.. In both cases it didnt start to leak until I did a few rev's.. The front and rear block rail are about 3.5" above the lifter valley so its not like its sumberged in oil so it has to be a crankcase pressure problem (I would assume?). The first time I had a PVC on one side with a good, free flowing breather on the other. This time I Installed 2 breathers and made sure they were not restircted to avoid having the same issue but apparently it didnt work..
Any suggestions?
Old Jun 22, 2009 | 12:10 PM
Duke94's Avatar
Duke94
When you say Permatex, do you mean RTV? You might want to run a leak down test to make sure you don't have excessive blowby for some reason (it happens)
Gary
Old Jun 22, 2009 | 12:12 PM
Peterbuilt's Avatar
Peterbuilt
A leak down test might help you to pinpoint the problem, apply compressed air to each cylinder if you hear air through the carb you have a bad intake valve. If you hear air out the exhaust you have a bad exhaust valve.
In your case you may have a cracked piston ring (or 1 installed upside down) and you will hear air through the valve covers. PG.
Old Jun 22, 2009 | 12:26 PM
...Roger...'s Avatar
...Roger...
Can you tell if the permatex was blown OUT or sucked IN ? Once the permatex is not where its supposed to be it just leaks but if you look close sometimes you can tell which direction it went.
Old Jun 22, 2009 | 12:36 PM
Fishndude's Avatar
Fishndude
Yes, it was the black RTV.. The small block 355 was dynoed (451hp) and didnt leak when it arrived.. The builder said he never really did any quick rev's and basically just did some pulls on the dyno after breaking it in. Both times it didnt leak for me until I did a quick rev off idle (to about 4000rpm).. I'm thinking a quick rev will build up pressure faster as opposed to a slow pull such as on the dyno..
Old Jun 22, 2009 | 12:45 PM
Fishndude's Avatar
Fishndude
I just looked and cant tell.. Can I assume its blowing out since its blowing the oil out I could see oil being splatterd that high off the lifter valley but to actually blow out another gasket and then start blowing oil out seems a little odd to me.. After it blew the gasket it will now leak even at idle but as soon as I shut the motor down, it wont even spit out another drop. Before applying the RTV, I wiped it all down, wiped it again with thinner and didnt even touch it with my fingers because I didnt want any oil from my hands to cause any issues. I also let it dry for 4 days before firing it back up..
Old Jun 22, 2009 | 01:30 PM
Duke94's Avatar
Duke94
You really need to run the leak down test to confirm (or not) that the engine is OK. No sense in guessing.
Gary
Old Jun 22, 2009 | 02:13 PM
...Roger...
Gary
Old Jun 22, 2009 | 03:43 PM
bashcraft's Avatar
bashcraft
Nope, just the opposite. Lugging the motor will produce more blow-by.
Old Jun 22, 2009 | 03:51 PM
Fishndude's Avatar
Fishndude
I think I figured out the cause.
The Edelbrock Elite valve covers have built in baffles under the breather port but the air vents are near the very top (just under the surface of the breather hole).. If you use a long grommet it will extend past the air port in the baffle, which means the air has to vent down and around the bottom of the grommet before coming back up and through the breather. If you use a baffled breather grommet it would be even worse. I think that caused enough restriction to creat some pressure because I just ran the car with no grommets or breathers at all (the baffles in the cover kept the oil from venting out) and it only dripped 2 drops of oil. I still have to change out the intake gasket again
Old Jun 22, 2009 | 07:08 PM
Duke94's Avatar
Duke94
Great find, nice work!
Gary
Old Jun 22, 2009 | 07:44 PM
Peterbuilt's Avatar
Peterbuilt
Good find indeed! Note to self: no Edelbrock Elite valve covers for me. PG.
Old Jun 23, 2009 | 12:12 AM
Z-man's Avatar
Z-man
There's nothing wrong with the valve covers - millions of engines have them with no problems. It was simple operator error...if that really turns out to be the problem.
To Crankcase Ventilation Help
