help right headlight stuck up
Old Jun 24, 2009 | 09:38 PM
buffaloc3's Avatar
buffaloc3
Default help right headlight stuck up
last night went to put the lights down and the right one stayed up .It was allways slow going down left one works fine where do i start and is there any test i should perform before i start buying part .The car is L48 1976
thanks for any help
Old Jun 24, 2009 | 09:41 PM
wer2xu's Avatar
wer2xu
if one works fine, its the actuator...replace the seal before you replace the actuator...go to wilcox for info.
Old Jun 25, 2009 | 03:54 PM
Oldguard 7's Avatar
Oldguard 7
Both of my lights are slow going up, the left one goes up first then the right. When I turn the lights off, the right light goes down slowly, the left sometimes stays up. I use the override switch and it goes down. I am going to replace the actuator seals, but purchase the actuators and relays just in case. I purchased a hose kit from Dr. Rebuild in 04, new in the box.
Old Jun 25, 2009 | 04:24 PM
wer2xu's Avatar
wer2xu
its usually not the hose. the doc has great trouble shooting guide, step by step on every component.
What I have found with a light/door that works, but works slowly is the relay is leaky and sending vacuum to the device, but at a slow rate.
Old Jun 25, 2009 | 11:28 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
This might help you!
Old Jun 26, 2009 | 09:09 PM
buffaloc3's Avatar
buffaloc3
thanks for all the help .Hope to get out there this weekend to take a look at it
Old Jul 7, 2009 | 10:18 PM
odiethe1st's Avatar
odiethe1st
8th Gear
Default Works as advertised!
I'd troubleshot to the regulators a while back and after changing them both, the headlights work great! Now how to remove the broken mounting screws that I enountered? They are pretty deep under the nose of the car to really get a screw extractor on them...beware to use plenty of rust eater to remove the mount bolts!
To help right headlight stuck up
