Carbotech performance brakes
Old Jun 25, 2009 | 04:31 PM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
Default Carbotech performance brakes
We take you deeper into the corners & across the finish line first.
When you want the control and modulation to take your track-bred car deep into the turns, you need unsurpassed Carbotech brake technology. Going deep before you brake allows you to stay on the accelerator longer going into the corner and even faster coming out.
If you're a professional racer, or if you're taking your street car to the track for club events, Carbotech has the best braking solution. That's why we are becoming the #1 manufacturer of performance brake pads around the world with professional and club racers--everyone who demands the best. At Carbotech, we've been heavily involved in club and professional racing for more than 17 years. We know what you need to win.
Smarter construction.
Only Carbotech uses a proprietary Ceramic and Metallic brake construction, not the carbon and iron used in conventional brake systems. Since carbon and iron combine to form carbide, which is used in cutting tools, you can imagine what those brakes are doing to your rotors.
Carbotech Performance Brakes utilize true race compounds that are "rotor friendly," eliminating the grabbing and locking up that keep so many drivers and race cars from performing at their peak. You want to go deep to gain those precious fractions of a second before you need to brake, and only Carbotech brakes let you do just that. In every turn, all race long.
Custom solutions.
Designed by racers for racers, Carbotech brakes can be specified to meet the needs of your car and driving style. Just give us a call and we can recommend the compounds that will be perfect for your front and rear pads and shoes, assuring that they perform together with optimum effectiveness
Old Jul 1, 2009 | 04:24 PM
Carbotech Adam
Supporting Vendor
Lapping/Track Days
Go Deeper Into the Corners on Lapping Days!
When you take your car to the track, you want to know you can charge aggressively into the corners and be sure your brakes will shear off that speed—giving you maximum control without unnecessarily sacrificing pace. Just call us and our racing specialists will help you determine the perfect brake pad compound for your car and your style of driving. Carbotech brakes are designed to allow you to “Go Deep!” while being particularly friendly to your rotors.
