timing moves..ever had this ?
i ahve been told to install 2 gaskets under the dizzy to lift it enough that it hopefully can torque down properly. ill do it in the next week or so and see how it goes.
When you put the dist into the manifold without a gasket, does the collar lay flush with the top of the manifold??
If not, just tightening the clamp is putting serious pressures on the drive gear and pickup and will eventually wear them down.
If it is, then I would put in the plastic spacer shims (they come in .030, .060 etc) they sell and then a gasket for sealing. Two gaskets will compress and the same thing will happen.
If it is flush, the clamp may be bent from the years and does not put the pressure on the dist collar.
First check if the distributor gear isn't bottoming on the oil pump shaft. Some clearance is necessary between these two parts ( about 0.02 to 0.04" ). Otherwise you can destroy a good oil pump pretty fast...
But I would prefer metal shims instead of plastic ones. They never crack or compress.
... a romac damper can slip. Suggest you don't assume any part's failsafe simply because it's widely-accepted to be top quality.
I'm not certain it slipped ... but suggest you should verify.
Thats why I suggest a simple mark on the pulley to match the mark on the outer ring of balancer. One quick glance rules out slippage of the outer ring. "Never be fooled again"
I leave my dist just loose enough to move if the shaft binds in the housing.
Better too retime if it catches, instead of snapping.
More than one person has had a dist shaft snap.
Might check the dist bush and that it is not gummed up.
12 month old msd so shouldnt be any binding or corrosion. be back soon to see what i find.
EDIT. . . I didn't see that it was a MSD distributor, I'm not sure how the shaft is made but this might still be something to check so I've left the original post below.
Boy, this brings back a horror memory for me! My 1979 when it had only 12k miles decided to do this exact same thing! I would set the timing, drive the car and it would change. I instantly went to the balancer and it’s a good idea to check this first! I did not waste time checking it; I just yanked it off and installed a new one.
I then set the timing, drove the car and it changed again! What the ????. I checked the clamp, checked, double checked and triple checked everything! Never in my mind did I ever think what was wrong would actually be the cause! It was the distributor!
I pulled the distributor out of the car and looked at everything real close! I pulled the shaft out and on first glance it appeared fine! I put the shaft in a vice and low and behold I found my problem, I could turn the upper plate ever so slightly! This is the plate at the top of the distributor shaft that is supposed to be made to the shaft. It was loose on the shaft and it was turning! New shaft solved the problem!
What was happening was when I would hit the throttle hard, the upper plate would move ever so slightly and change the timing instantly.
I hope this helps, and you should also check the balancer but. . . Check it before you remove it!
Willcox Inc.
so just recently when my car started to stumble at high rpm i jumped to conclusions and thought the same thing had happened again as it seemed such a similar feeling. i took on everyones advice and went out to the garage today, put the light on my balancer and guess what- its on 12 degrees exactly where it is meant to be so DAM its not timing.
i then checked my idle mixtures which is 4 point on my demon 750 and oh oh they had somehow screwed out to 2 full turn. one of them was 3. i put them all back in to 1/2 of a turn from lightly seated which is where i like it and WHAMO i go for a drive and HELLO BOYS IM FLYING AGAIN. i must have been fowling the plugs at every lights and then stumbling on the next run. it now goes like a dream but dont worry , ill be back here in a week with some new problem im sure.
im going to smash a heap of them tonight now..beers that is
