Spring mount height??
Old Jun 27, 2009 | 02:10 PM
rumblefish's Avatar
rumblefish
7th Gear
Default Spring mount height??
Does anyone make a spring that would allow me to run a shorter connecting bolts at the end of the spring? With the offset that I run the current set-up is too close for comfort to the inside of the rear tires. Can the mounting pad on the rear cover be machined or the spring pad on a fiberglass spring be altered? I am using 16x10's, with offset control arms. If I could run a shorter bolt I could possibly tuck the whole thing inside the wheel. Thanks
Old Jun 27, 2009 | 03:18 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
I'd caution milling the spring mounting pad on the diff cover enough to gain any significant difference, as I've seen a number of early C3's with broken spring bolt flanges (this may be one reason later C3's have smaller diameter spring bolts), but FWIW you can gain most of an inch by "raising" the diff in the chassis, a la Chevy Power tip for road racing ride heights. Of course, conversion to coil-overs would eliminate the issue.
TSW
Old Jun 27, 2009 | 04:11 PM
...Roger...'s Avatar
...Roger...
Would a shorter spring help ?
Old Jun 27, 2009 | 06:04 PM
noonie's Avatar
noonie
I use this shorter lower leaf with some of the original leafs removed.
http://www.guldstrand.com/scripts/pr...?idproduct=106
Old Jun 28, 2009 | 03:07 AM
TheSkunkWorks
Don't know why I overlooked pointing this out, as I have a short Guldstrand main leaf myself...
To Spring mount height??
