No dash lights
Old Jun 27, 2009 | 11:34 PM
Brown78's Avatar
Brown78
Default No dash lights
I've checked the fuses. All good. I can turn the light switch all the way to the left and the dome floor lights go on. I'm hoping it's only the light switch. Has anybody had with problem. Before I start removing something I don't need too.
Old Jun 28, 2009 | 09:29 AM
...Roger...'s Avatar
...Roger...
Put a test light on the INST lamp fuse and turn the headlights on and rotate the **** back and forth-test both sides of the fuse. If you dont have power at the fuse then it could be in the headlight switch. If you DO have power at the fuse then your problem will be in the dash or the wiring or the printed circuit going to the dash lights.
Old Jun 28, 2009 | 02:55 PM
kansas123's Avatar
kansas123
Years ago I had the same problem and when I replaced the headlight switch I was back in business.
Old Jun 28, 2009 | 03:42 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
As a follow up, if you do or don't have power to the fuse, you’ll need to pull the cluster anyway to get to the wires or the switch.
Here are instructions should you need them. http://willcoxcorvette.com/repairand...lp.php?hID=146
This should only take you a half an hour or so to pull. But before you take out the headlamp check the wire on the cluster connector for power. This wire in the connector is the fourth wire down from the top on the driver side. Also check the fingers that the connector makes contact with, sometimes they will be corroded and/or messed up from someone else being in there.
If this fails, I would go directly to the headlamp switch by reaching inside the speedo tach hole and un-plug the connector.
Willcox Inc.
To No dash lights
